  • Replies 246
Posted Images
Hey Brad, I'll shoot you a PM in a couple of months and if you still have it we can go from there. I'm just in the middle of paving out the back so have no funds, but it doesn't stop me from dreaming. rolleyes.gif
What model is it and price etc - would you send to Perth? Send me a PM if you wish.
Anyway, enough welding talk and more welding action....here are some photos of some recent work.
I am doing some standard replacement parts for VL's (under a new business name, Red Star Fabrications) at the moment as well as custom made aluminium parts for the engine bay. In order of the pics, they are:
- fuse box cover
- power steering fluid canister
- fuse box replacement catch can and surge tank
- mixed bag of goodies lol
I will be doing some other goodies as well. I have custom made catch can to sit inline with the bottom of the radiator, custom made intercooler with diffusers in the end tanks, replacement fuel tank, complete one-off rb26 intake manifold.......so keep an eye on this thread. This is just the beginning of new things to come :action-smiley-069:
Happy welding,
Ariel
....a few from the weekendas promised. This is all done using straight, 100% argon.......BRING back my helium mix PLEASE!!!! My duty cycle went down the sh1tter!!!
XR6 "Race Version"
and last but not lease, please, please do not ever charge a cusgtomer if you weld like this. This customer has come to me for his 3rd intake manifold.The previous have both cracked and leaked!!!
Isuzu G200 LPG Turbo which will incorporate "Nitrous pro-flow' burst panel
They have more problems then that, the plenum split. I just got pics.....hardly any penetration of the material. Poor material preparation, poor welding technique, not enough heat, material not cleaned before welding...the list goes on.............
I will be using 6mm and most probably making 2 passes over it, finishing it off with a weave or "walking the cup" style bead. I have done it before on another LPG plenum made of 10mm...that had 3 passes over it and turned out absolutely mint.
I can't deny that I have. Having said that though, this was all prior to me welding them which has been for the past 2 years or so.
I did make some design changes as well to help sort the problem out since it has only really happened to ones I was making some 4-5 years ago.
I actually offer a lifetime warranty as such to continue supporting my customer base.
Why do you ask?
yo ariel, how much do you charge for that catch can? (with slip on hoses, not threaded fittings) & do you still make the custom fuel rails to suit 14mm injectors? i think they can work with the neo injectors if you just get the right o ring & grommets in and it will fit. (another member did it with a HKS copy rail - are your designs same as the HKS one?) cheers
No worries BR, whenever you are ready, just let me know.
Elvis - catch can is $200. Not sure of what other memebers do, I don't really copy things. I can only make the rails for 11mm or 14mm oring injectors. I may need the complete manifold since it is a NEO and I dont have any of those handy.
Ariel
  • 1 month later...
    • If the tyres were fitted when new, I wouldn't expect much over 5 years of use. Especially if the car lives outside full time.  If the tyres had been stored under ideal conditions and are being purchased new, I'd fit a set of already 5 year old tyres if I only expected to get 1 to 2 years of use out of them.  I've purchased many a set of new (but quite old) tyres from St George Tyres when I just needed some decent rear tyres to drift on.  Here is a pretty crazy example, can't say I've ever bought 11 year old tyres from them before though lol.  https://www.stgeorgetyres.com.au/momo-tyres-245-45-17-outrun-m3-official-product-by-momo-italy.html
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
