  • Replies 246
Posted Images
Yeah they are close. Now its just me that has to improve. I'm letting the machine down and not the other way :)
Easiest to just buy a welder and practice, there is no substitute for it.
Cheers,
Ariel
  • 4 weeks later...
I have been a busy little elf, filling in my week off with a little bit of work, tying up some loose ends really. All pics are taken, straight after it has been welded, no cleaning at all
Custom Fuel Cell - with internal pumps on custom mounts, completely baffled, rear extension acting as internal surge tank/extra baffling, removable lid for access to pumps, fuel level sender and filler lid along with return and one way valve to be fitted. It holds some 63'ish litres. Will be coming back with the car for custom made mounts, not your average square tube.....just the norm is not good enough for this kind of work :whistling: and ignore the Nissan bolts, they are being replaced with Stainless steel, button head screws....in my opinion, it's the little touches that make all the difference
Catch can to sit on chassis rail in engine bay - internally baffled
Again, not your average mounting bracket. Admittedly, nothing special, but not just some sheetmetal with a 90deg bend in it.
Undercar surge tank - complete with twin fuel pump bracket....ooops, I'll have pics tomorrow, didn't realise I didn't take any of it today
I made some minor changes to the welder settings and also the way I sharpen the tungsten to try something different and through the helmet, they seemed to be in the right direction....will it ever end??? Now I am making more and more changes depending on what I am welding then ever before, maybe I should just stick to what I have, but it's hard to not to try and get better all the time.
Happy welding,
Ariel
Better quality pics of the internals of the fuel cell and in car pics (Not quite finished yet, going to cop stainless bolts for the lid and custom brackets) Welding work is second to none! Looks unreal and it hasnt even been polished yet!
I have been busy getting stuck into a CA18DET powered Datsun 1200 ute and hence the reason for no updates. I did make another undercar surge tank today and have the new rb26 and sr20 manifolds still in development, a little slower than anticipated unfortuantley, but isnt that the way it always is with cars???
What started off as a plenum and piping only job has turned into what more and more people are looking for once they see what kind of work I can do, much like the turbo'd GTI I posted pics up of. This to-do list now looks something like this:
- new intercooler and radiator installation
- inlet manifold integrating PCV valve, intercooler piping and recirculating blow off valve
- new exhaust manifold flange, yep meaning remove existing one and weld on a new one - DONE
- port match inlet and exhaust manifolds - step 1 of 3 DONE
- new fuel tank, surge tank, 2x044's and stainless steel fuel lines to permanently convert from pump to e85
- new front radiator support panel and front apron
- new custom made engine and gearbox mounts to move everything back to be able to hide intercooler behind grill
- converting 8 port cylinder head to 4 port - DONE
- clean up inlet and exhaust ports
- raise compression ratio, new cams, head gasket, springs, balancer
- fill in all the holes in the engine bay and spray
Anyway
This is just a little something I made for myself....its been a looooooooooooongtime since I spoilt myself but needed it for the CA. Notice the space for 32 valves :thumbsup: VH45 goodness :nyaanyaa:
  • 1 month later...
some welding pics from this weekend. I am always trying different things to improve structural and aethestic's of the weldand to me it looks like they are working out.
I'm playing with tungsten stick out from the cup, tungstens sharpening angle and also the penetration settings.
  • 3 weeks later...
Here is some more of my latest work
Machine and replace the top of a strut cover - machined the top off, not touching the baffles and replaced it with some new sheet
Surge tank enclosure with removeable front
Custom porting on CA18 cylinder head finished, assembled and ready to bolt on....complete custom intake manifold coming shortly
Should be able to post up photos of the new fuel system for the Datsun ute if I finish it this weekend. Stainless steel lines from front to back as well as mounting a modified r31 fuel tank under the rear of the tray and surge tank in the front of the tray. The surge tank was going to be mounted underneath, but that will get in the way of the new suspension being installed.
New sr20 s14/15 intake manifold flanges....did someone say complete custom intake manifold for under $1,000 just add a fuel rail and throttle body :)
  • 1 month later...
Some of the recent work
stainless steel fuel system to suit e85 - 2x 044 fuel pumps, carter lift pump, and thickwall stainless tubing with as little angle fittings as possible. All bent in a tube bender.
exhaust manifold and dump pipe for Nissan Micra..... this is my first crack at an exhaust manifold and my first decent steel tig welding job. I am loving this steel business.....give me more LOL
  • 4 weeks later...
Guest
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
