Hi everyone,
As per the question on the topic, does anybody know if a manufacturer makes an amp with an optical input?
I have a JVC head unit I bought quite some time ago & have now installed to replace my dead Pioneer unit & found out after I purchased it that it has optical out.
It seems strange to have this feature on the head unit but no manufacturer that makes an amp to take it including JVC themselves!
Would make a lot of sense to get rid of all the bulky RCA leads & replace them with one smaller one that also happens to eliminate some sources of interferance & the possibility of ground loops.
Cheers
Jared
Edited by J_Red33
Hi everyone,
Cheers
Jared
you could prob get one from overseas - look up car amp with optical input in google
Alpine, 5 channel amp, MRA F350 , 550 also
Kenwood had a few
Coustic did as well
Audison processor
most are to simplify a multimedia setup
pretty random and most arent made anymore
most people stuff the link when they install it , so why bother unless you drive a silent car that you can hear the difference in the noise floor and dynamic range ????
troy,
because its cool to have - everyone knows that..
that market died a LONG time ago. also unless the have a totally DEAD room you are not going to hear any difference. a car is FAR from that.
every thing in a car is a trade off. want more speed - lighten it and it becomes louder. deaden it and its quieter but you notice the speed difference.
Have been here already, and didn't find much. Nothing in Australia anyway.
Or possibly look in to a signal processor (audison/alpine), you'll still probably end up using analogue from that to your amp(s) but you get a lot more tunability.
Defeats the purpose of having the lead in the first place unfortunantly.
I did omit to mention that one of the reasons I was looking into this was due to excessive noise in my system & thought if I upgrade to an optical setup I could eliminate one source of electrical noise.
Having said that I have been doing a bit of research & with what testing I've done previously, I now suspect I may have a ground loop either to my antenna or my left rear speaker. After disconnecting the RCA leads to the Amp I still have noise on this speaker. Changing amps also does not cure the issue
Kenwood had a few
Coustic did as well
Audison processor
Thanks for the info may I ask what you mean by 'the link'? I was figuring I could just plug the Toslink lead straight from my head unit to the amp so I'm guessing I'm missing something here...
troy,
This does somewhat surprise me considering most new home systems are going to digital one way or another, whether it be Toslink, Coaxial or HDMI & unsually all three on premium systems. Not to mention the parts in circuit for going full digital are no more expensive & sometimes work out cheaper.
For what info I've been given. Will have to look into things further.
Edited by J_Red33
if you need toslink to remove noise you have a bad install of equipment failing. did you ask the question here for the noise ? I live in adelaide south if you want to meet up sometime, so I can listen to it and advise ? or post up the recorded noise and a small list of affected items, models as well
I'm sure the noise can be resolved without toslink.
dont forget home systems can use digital signal paths much easier then a vibrating, noisy, harsh environment car can. ditch the toslink idea
more then likely its not going to fix the noise on a bad install
This was one reason yes, & I was considering upgrading my amp from the crappy Cadence unit that rushed into the purchase of when I bought the car due to a hunger for some good audio.
It was not a good install, I have almost completely re-routed and replaced all the cabling appart from the RCA leads (also candence brand) and the ignition feed to the head unit.
The source of the noise is from the alternator as there was no noise with it disconnected when the engine is running.
I did end up replacing the alternator as I did discover it was giving the occasional 3V spike (measured with a oscilloscope). Replacing it did improve the problem but didn't eliminate it.
Other than the noise though admittedly the sound has actually improved with the new head unit so if I could cure this I'll blow my dough on an Intercooler kit instead :blush:.
I do head down the southern suburbs a bit as I have family down there, so would appreciate a specialists opinion. I should also try pluging another speaker into the left rear connection just to see if that makes a difference as it doesn't matter what output is connected to the amp.
Sorry if this seems a bit strange the way I am recalling all this stuff out of the blue. My ride was off the road for quite a while & only now am I getting back to the issues I was originally trying to fix.
Thanks will keep it in mind if I decide to go down this path
Edited by J_Red33
Other than the noise though admittedly the sound has actually improved with the new head unit so if I could cure this I'll blow my dough on an Intercooler kit instead :D .
shoot me a pm sometime if you want me to listen to it, and that clarion stuff is from 2006
if you go that route contact Chris Rodgers on here, he sells that brand
cheers
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
    • I'm late to the party. Been busy with a newborn... Keeping me up at all hours of the night.  I'll look into purchasing ID 1750's then! Thanks everyone for the concrete evidence.
