hey mate ,do you run themo fans on your set up ??as i have a twin turbo rb 30 /25 set up running 488 rwkw and i was running themo fans and driven around wasnt to bad but i soon as i got a red light or went through a drive through temps would clim ..up ..i pulled the themos off and put the standed fan back on ,and didnt have any more troubles with the temp climming.
cheers
I'm not sure exactly what these thermo fans are but I havnt touched the fans so it should be running whatever fan came with the car.
As far as the climate control goes.. if you push the recirculate button, does the hot air stop blowing?
unfortuntely all it does is limit the amount of air. I can still feel the hot air.
there is a sensor that is prone to breaking, its near the windscreen on the inside above the glove box.
when it goes you basically have 2 settings.... 18 (cold) and everything else (hot)
you need to turn it to 18 and then turn it off to get it to stop blowing hot air :ph34r:
I'm still in the process of checking all the sensors but I just tried the system today (raining and all). it blows cold air but the more I drive the car te air gets hotter. regardless if it's on 18 turned off or on.
almost sounds like the 'heater core' tap is stuck on, as well as the cowl door not closing properly, probably the seal is cactus
Edited by BundyBear
any thoughts on solutions?
have a search on SAU for heater threads you should find plenty of info on the heater. being a 33 owner I'm not familiar with the 34 BUT if ya stick ya head under the glove box and hit the 'recircualte air' button, you should see a 'rod and lever' arangement mo0ving, thats the cowl door. Same goes 4 the heater cores tap, change the temp and something will move to direct the water flow.
like I said though do a search. I'm sure I've seen full removal guides and all.
had a similar issue in my car, turns out the interior temp sensor was unplugged, in my case it was a r32 and the centre console got removed and the sensonr never got hooked up, if there is no signal the aircon assumes the temp is -44 degrees and pumps in hot air to stop you dying...even if the thing is switched of, this really sucked in QLD in summer and i was so glad when i found such a simple fix!
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
