hey guys putting my 180sx up for eoi will sell at the right price or swap for an s14 or even an r32 with a rb25 but open to anything show me what you got
180sx 115000kms recod motor has only had 45000 according to dash in half cut however speedo was also not working hence not using it
body isnt to bad few minor dings no major damage or accident history previous owner thought nissan didnt do a good enough job of installing the door trims so he put a few self tappers through it... (thank god the stereo was the only thing he touched) i have removed them and fitted clips however holes are still there barely noticable dash has a hair line crack however still looks the part
2871 bb turbo
fmic
airfilter
na cams
full turboback exhaust
power fc with hand controller tunned
king springs
excedy heavy duty clutch
turbo timer
walbro fuel pump
schenider cd mp3 player + 4 speakers sounds great
has 17x9 rear 17x8 front sparco style rims will drop price if sold without wheels
made 194kw@10psi at bel garage
im sure theres more mods which i havent listed
the car has not been boosted past 10psi it has a very safe afr the way it is and more than enough power for simply getting around town and the fuel economy is amazing however with bigger inj and a retune you will see a sustantial increase
reason for sale my sr corolla will be comming out of the shop very soon and it has s13 front end so i wanted abit of a change from the s13 series
prefer swap however $8750
ono
beter pics will be up in the next few days
  • 3 weeks later...
swaps for r32 sedan?
basic mods
rb20
hks fmic
arc intake
kakimoto catback
hks bov
hicas locked
rays wheels 17x8/9
cusco rear coilovers
hks turbo timer
5" splits front
6" rear speakers
5% tints
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
