can any one out there tell me what type of car alarm this remote comes from and or any info on the alarm its self. i can find the alarms cpu so i cant get a name for it .....
anyway, here is a picture of the remote.....
https://www.sau.com.au/forums/topic/30428-help-needed-on-car-alarm/
here u go i found it
http://www1.omnitel.net/gdj777/prod08.htm
hope it helps ya!!
thats mate it did ....
however maybe u can fill me in some
on the remote is yours :
1- lock car
2- unlock car
3- remote start
red- i have no idea .....
my troubles are thats sometimes i can unlock or lock the car with no problems , then other times i cant even unlock the car, i spend 15 mins walking around it pushing buttons and it dose nothing * and yes i have put a new battery in remote and the car battery if new also * this is a reaccuring fault and i have no manual for it nor do i know the name of the alarm .
anyway ive sent an email to that website contact and hopefully they will respond.
in the meantime any help would be great
cheers
Ron
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
