Can all SAU:SA Members please follow the link below and head to the SAU:SA Members forum to vote in your new 2010 Executive.
http://www.skylinesaustralia.com/forums/Sa...te-t304291.html
Voting closes Jan 31st 11:59pm.
That is all.
https://www.sau.com.au/forums/topic/304292-sausa-executive-committee-voting/
Thanks Krishy, but kudos should really go to Damo - he found the site and pointed me in the right direction. We were going to just use SAU threads with polls, but I eventually discovered that there is no way to hide the results once someone has voted in an SAU thread. Hence we went to Damo's PollDaddy plan :)
SAU:SA Members, please be aware - if I thought for one microsecond that anyone was going to try to hack/spoof or in any way interfere with this voting process I will ban them for life and they will get a personal visit from some of the execs. If I even suspect anyone of doing this they are gone from SAU for life. No questions asked.
We are tracking IPs closely and even if people attempted to circumvent this we would be able to tell, as we get IP locality reports also.
We have purposely made a voting system where people don't have to register and go through the rigmarole of identity verification and tracking, but if we hear of one more person even mentioning anything untoward in the voting process we will implement this next elections. Or even worse will make you all turn up on the same night and vote in person, which will be much less convenient.
It does sound like a child/incest porn site, but it certainly does its job well!
The votes are in, counted, and the nominees have all been informed of their results.
I will start a fresh thread once I have received the acceptance by all winning parties, and notify everyone of the new and continuing Committee members.
Thank you.
:P
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
