  • Replies 48
Got it done at AAA eh? Good stuff!!
Tell us what you got done, what you thought of it.. hehe Im suprised you paid 1400 tho. I guess they probably realised by now they were underselling themselves compared to the competition!
I'm glad u didn't go D&T.
I was horrified when I pulled the dump pipe off. Where the 3" S/Steel is stretched over the flange the bottom of it didn't quite get stretched enough. This caused A V raise in front of the compressor wheel. Not to mention all of the welding slags spots that were splattered everywhere inside the dump pipe. The final weld on to the flange was really rough i.e not diegrinded. For $1700 that I paid (slightly different muffler to the $1650 price) I expected a 100% professional job. Not rough slap it together job. Also bits were painted on the exhaust which flaked off after the first wash/rain and the welds are now starting to rust. When looking at the back of the car you can see the flat bit of the large rear muffler. The black paint there flaked off in the first week and looks daggy. Also when removing the dump pipe the bolts had been rounded off and not sitting flush up against the flange as the weld slags was holding the bolt from sitting flush.
The note and sound of the exhaust is nice though.
Im surpised D&T did such a bad job. I thought they would have used an 'off the shelf' dump/front pipe kit because its much easier and better. Looks like D&T isnt the place to go to then. They look more like a V8 place anyway...
I had the exhaust place across the road check it out and they said they diegrind the weld inside of the dump pipe so its nice and smooth. I think the place across the road from D&T is called Exhaust Techniques or something. They wanted $350 to fix up the dump pipe. I didn't bother as the RB30E is 30mm or so higher than the RB20 so I am going to have to get another dump pipe fabricated.
Also D&T made the dump pipe/front pipe as a single piece which was a real pain in the arse when removing it. Well compared to having a flange that seperates the front and dump pipe.
I'm not sure if the V infront of the exhaust wheel is causing extra lag or not as I make around 1-1.1 bar of boost at 3500rpm.
If it wasn't for the shitty paint and messy dump pipe I would have been very happy with the job.
Extremely happy with AAA, Gordon down there knew his stuff, showed me the ressy and muffler that he was going to use and a dump pipe that he had made for another customer just so i could see what the final job was going to look like. Ive got the supercat cannon muffler hanging out the back and he tilted it in such a way so that the muffler has enough ground clearance but still sticks out at an angle like the jap systems do, he explained all this to me which was much more than what D&Tand ET did. D&T offered me a free dyno run before and after but i was cautious of this as when they did the exhaust on my ET pulsar they told me they would do the same but then didnt and made up the excuse that my radiator was leaking and they didnt want to risk it, could have told me when they found the leak untill waiting until i handed over the money.
Thats the big problem, noise is reduced by increasing back pressure - a quiet exhaust is a restrictive exhaust.
Thats the good thing about the apexi flap, 1/2 a second to open it or shut it. So when you are just cruising, you dont get added attention.
What exhaust do you have?
Guys I beg to differ re resonators!
The Trust system on my car has a resonator (offset design) that I recently had flanged for easy install & removal. Bloody hell did it make a difference! With the straight through pipe exhaust note is deeper (very tuff sounding :) ) & it certainly is louder. Thankfully it's not annoyingly loud due to the design of the Trust muffler.
I'd go as far as to say I'm 99.9% sure there's an few extra rwkw to be had with the resi out.
With the resonator in - exhaust is very quiet until you go WOT (just what you need for cruising). In fact the turbo/induction noise is faaar louder.
With the resonator removed - extra exhaust noise/deeper note is noticeable even at idle.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
