Hi everyone,
Thinking of purchasing a car here, and if i do go ahead with it i guess i will have to drive it back to Sydney.
So just wondering how long will it take and if its worth it? Or should i just get a car freight company to do it?
Cheers,
Sidd.
https://www.sau.com.au/forums/topic/304343-driven-to-sydney-before/
I drove my R34 back from Sydney, gave me an opportunity to familiarise myself with the car - it was a fairly pleasant trip despite lack of any real stereo (AM/FM had been retuned for aus chans, but otherwise had a tape-deck).
I had an alarm fitted and my car booked into Croyden whilst over in Sydney and had a complete inspection (so I could take it back to the yard if they found any probs my pre-inspection hadn't picked up) and to fit a 3" turbo-back exhaust. I did have the benefit of being able to crash with friends in Sydney to make that easier on me though.
The drive back itself was fairly uneventful and long - took about 15-16 hours in all, sticking to the speed limit - taking plenty of breaks. It's a drive I've since repeated a coupla times since then as I have friends/family in Melbourne and Sydney (sometimes going direct to Sydney via Melbourne to shake it up - doesn't take that much longer and gives more interesting scenery).
drive it, its not that far.
frieght company will more than likely flog your car before they put it on or fling it up there with a forklift if you dont give them the keys.
if you can con someone into going just swap drivers every now and then and it'll be easy as.
The trip is done in about 14 hours for me in the camry i left sydney at 4.30am missed heaps of traffic personally it will take more fuel in a line so car carrier might be better and safer for break downs
CVAR i think it is looks wrong now, someone will correct me charge $400 on a truck they mark off all prior damage and you sign off both ends
Just drive it back (nothing better then a road trip) and as above it will get you used to the new car and assure that no damage is caused via a freight company etc. Last time I brought a car back from Sydney I took 2 days x 8 hours (I wasn't in a rush though).
Ryan
o and i used to work in transport and its 3 days standard, less you wanna pay double for xpress and have it go overnight.
and i shudder at the thought of a decent skyline going on the truck the same as the things i seen packed.
Edited by Inline 6
Once you start driving you prolly wont want to stop unless your feeling fatigued, my trip went very smooth and easy
In comparison my trip to melbourne in the r33 made me tired and sleepy and thats an 8hr trip
So say 16-17 hours max. Thats not too bad i guess!! Might just make a stop over somewhere.. have a nana nap and keep driving lol.
Cheers guys!!
If you do have a stop over I recommend staying in "Hay" it's about half way and a pretty decent town.
Done it before when I picked up my Stagea from Sydney. Drove to Wagga overnight, then Mildura over night. Made a nice road trip of it. I've had freight companies damage my cars before, and don't trust them. They worm their way out of fixing it as much as they can. :ph34r:
hahahah looked myself as there near my work
its CEVA sounds similar
me and a mate did adelaide, sydney, newcastle, and then adelaide without stopping for more the fuel or food.
we had work comitments so taking nanna naps werent a option.
in all we did 3200 kays in 36 hours.
i wouldnt recomend it to most people but, we took turns, and got the job done.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
