Hi everyone,
Thinking of purchasing a car here, and if i do go ahead with it i guess i will have to drive it back to Sydney.
So just wondering how long will it take and if its worth it? Or should i just get a car freight company to do it?
Cheers,
Sidd.
https://www.sau.com.au/forums/topic/304343-driven-to-sydney-before/
I drove my R34 back from Sydney, gave me an opportunity to familiarise myself with the car - it was a fairly pleasant trip despite lack of any real stereo (AM/FM had been retuned for aus chans, but otherwise had a tape-deck).
I had an alarm fitted and my car booked into Croyden whilst over in Sydney and had a complete inspection (so I could take it back to the yard if they found any probs my pre-inspection hadn't picked up) and to fit a 3" turbo-back exhaust. I did have the benefit of being able to crash with friends in Sydney to make that easier on me though.
The drive back itself was fairly uneventful and long - took about 15-16 hours in all, sticking to the speed limit - taking plenty of breaks. It's a drive I've since repeated a coupla times since then as I have friends/family in Melbourne and Sydney (sometimes going direct to Sydney via Melbourne to shake it up - doesn't take that much longer and gives more interesting scenery).
drive it, its not that far.
frieght company will more than likely flog your car before they put it on or fling it up there with a forklift if you dont give them the keys.
if you can con someone into going just swap drivers every now and then and it'll be easy as.
The trip is done in about 14 hours for me in the camry i left sydney at 4.30am missed heaps of traffic personally it will take more fuel in a line so car carrier might be better and safer for break downs
CVAR i think it is looks wrong now, someone will correct me charge $400 on a truck they mark off all prior damage and you sign off both ends
Just drive it back (nothing better then a road trip) and as above it will get you used to the new car and assure that no damage is caused via a freight company etc. Last time I brought a car back from Sydney I took 2 days x 8 hours (I wasn't in a rush though).
Ryan
o and i used to work in transport and its 3 days standard, less you wanna pay double for xpress and have it go overnight.
and i shudder at the thought of a decent skyline going on the truck the same as the things i seen packed.
Edited by Inline 6
Once you start driving you prolly wont want to stop unless your feeling fatigued, my trip went very smooth and easy
In comparison my trip to melbourne in the r33 made me tired and sleepy and thats an 8hr trip
So say 16-17 hours max. Thats not too bad i guess!! Might just make a stop over somewhere.. have a nana nap and keep driving lol.
Cheers guys!!
If you do have a stop over I recommend staying in "Hay" it's about half way and a pretty decent town.
Done it before when I picked up my Stagea from Sydney. Drove to Wagga overnight, then Mildura over night. Made a nice road trip of it. I've had freight companies damage my cars before, and don't trust them. They worm their way out of fixing it as much as they can. :ph34r:
hahahah looked myself as there near my work
its CEVA sounds similar
me and a mate did adelaide, sydney, newcastle, and then adelaide without stopping for more the fuel or food.
we had work comitments so taking nanna naps werent a option.
in all we did 3200 kays in 36 hours.
i wouldnt recomend it to most people but, we took turns, and got the job done.
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
