i have for sale a top secret front bar for R34GTT.
bar is made out if fiber glass. excellent condition. in gel coat ready for primer and paint.
some small areas of the bar has been re filled by me cause i wasnt too happy with the finished product so just to make it a be more smoother and nice and flat i did some extra filling.
bar also has hooks so you can put your own mesh on and bend it to lock it in place.
im after $300 for the front par and willing to send interstate at your expense. i use pack and send and would be around $100 or less then that to get it packed up nice and tight and send interstate.
will post pics of actual bar when i get hold of a camera but this is what the bar normally looks like
http://www.skylinesaustralia.com/forums/post-a239732-
https://www.sau.com.au/forums/topic/304359-top-secret-front-bar-r34-gtt/
^^ they are 2 different bars
First one is a copy of the Top Secret R34 GTR front bar, cut to fit narrower R34 front guards and different bonnet.
The second pic (DMD) is a copy of the Do-Luck bar.
cause im really nice and really need to get rid of the bar as its sitting in the middle of my pagola lol $200 pick up (may be able to deliver to you if your local)
if this does not sell by friday then its going in the shed where when things go in it does not come out for a while cause its a pain to do so lol
grab yourself a bargin. cheapest iv seen is justjaps which is $450 or $500. so come get it.
hey mate
it will fit but you will have a gap between your bonnet and the grill unless you have a bonnet lip which will cover the gap.
what bar are your currently running?
    • Oh, yeah, look - here's the thing. You always replace the tensioner when you're going in there to replace a belt....under normal circumstances. You want to make sure it is good and safe, and that you don't create a reason to take the front of the bloody motor apart again. But in this case, OP is replacing a belt that has aged out on time, not usage. The belt is a million miles away from aging out on usage. The belt gets a time "limit" merely because it is made of rubber and can degrade naturally. The tensioner? Not so much. I reckon it could last forever on the current usage pattern. So I reckon if the thing is going to continue to get used at the same rate, replacing the tensioner is somewhat gratuitous. Would I replace it if I was doing it on my car right now? Hell yes. Because my car does 10-20 thousand kays a year. So it's all going to be the same thrashedness. Would I YOLO it on OP's car. More than likely.
    • I dunno. I think any one of those from each side to sump is probably enough. Remember - this is about creating a path for gas flow up from the sump to the cam covers. That gas flow then has to leave via the lines to the catch can. There's probably little point in providing 100% more capacity from sump up to covers cf. what you have from there to the catch can. Put in the 3 convenient ones? Any which way that you see fit. That'd be my thoughts.
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
    • Tapin,    So got mine up and realize a few things. First was my slave line doesn’t reach the other side, so I have to get a longer hose made. I want to ask did you have to extend your wires for the CD009 sensors? One on the driver side(right side of car looking at the car from the rear) and one on the passenger side( the left side of car from rear). And do you know what those two sensors are respectively? I know it’s not Speedo since we talked on this already. And I may have to separate the trans again to swap out throw out bearing. We will see. Did you run your RB slave cylinder? I know you cracked your original but replaced it with a nismo. But wasn’t sure if you bought the one designed for the CD009 or not. Thanks
