Hey guys just got me a 2003 350gt sedan and wanted to know if these would fit with the tyres mentioned. If so is this a reccomended solution? i can get a good price on this package. Does anyone have these wheels on a sedan already? if so do you have photos of what they look like on?
DTM Hiro
2x 19x8.5 +33 offset
2x 19x9.5 +40 offset
5x114.3 73.1 centerbore
Tyrer
2x 235/35/19
2x 245/35/19
https://www.sau.com.au/forums/topic/304391-19-dtm-hiro-wheels/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
