  • Replies 51
RB30DET.
Where the engine rebuilder is getting the pistons, they open up apparently this week, so its soon. ;)
If you don't go forged pistons in the RB30E short motor and use the standard NA pistons you will have a 8-8.3:1 CR, which is good for turbo. Without forged pistons you will be stuck reliably at 250rwkw with a good tune. If you start heading towards 300rwkw the cast pistons wont handle the heat and break.
I used a R32 GTS RB25DE head (Like yours) had it rebuilt, ported/polished & inlet valves deshrouded. The cam specs for the head are 240dur 7.8mm lift on the inlet and 232dur 7.3mm lift on the exhaust. I'm going to use the 240dur 7.8mm exhaust cam from my RB20DET to help open up the top end a bit more. If it makes power to 6000-6500rpm then starts to drop off I'll leave the cams standard. If it drops off before 6000rpm then I'll throw a set of 256dur 9mm lift cams in it.
Do your figures. Work out how much its going to cost to get an RB25DET & RB20DET in the car with a working ecu (RB25DET = wiring mods, RB20DET will work easily with a T ECU), then work out what it will cost to give a RB30E short motor a freshen up (~1-1.2k) buy a head gasket, bolt on your RB25DE head, pop down to a jap importer & grab your self a cheap highflowed turbo, buy an second hand exhaust (~$700) then get your ecu remaped and have a solid easy 200rwkw with no lag and quick acceleration as you idle off from a set of lights. :P
It stresses me having to play with the clutch then waiting for the turbo in first to try and take off a little quicker than normal.
..Do your figures. Work out how much its going to cost to get an RB25DET & RB20DET in the car with a working ecu (RB25DET = wiring mods, RB20DET will work easily with a T ECU), then work out what it will cost to give a RB30E short motor a freshen up (~1-1.2k) buy a head gasket, bolt on your RB25DE head, pop down to a jap importer & grab your self a cheap highflowed turbo, buy an second hand exhaust (~$700) then get your ecu remaped and have a solid easy 200rwkw with no lag and quick acceleration as you idle off from a set of lights. :P
I should proibably point out that i only have an RB20DE atm, meaning to go to RB30-type stuff, i would need another head (RB25DE) as well as block, turbo, ecu, wiring, Dump pipes, Intercooler etc, etc. as you've already suggested. some things i was wondering about though are the RB25DET you said would require a wiring change - aren't the sensors and stuff the same? it would definitely need another ECU to handle the increased airflow, different capacity etc, but shouldn't it just plug straight into the existing harness? As for the RB20DE, would that even make a worthwhile difference ? or would it be bettter to just hold off and go all out with the RB30 idea? <- this last ones open for comment, btw.
phil
Joel,
You forgot to mention new injectors and fuel pump also, as the GTS Gear won't cope.
Trust me I added up the cost both ways for my conversion, and the RB25DET works out a lot cheaper, every time!
It's costing me:
$2100 for a 1995 RB25DET (64,000 km) engine, ecu, intercooler, wiring loom and fuel pump
$600 for a CES twin dump/front pipe (though you could get a cheaper single dump for $250)
$315 GReddy Turbo timer and Apexi pod filter
$800 labour to swap it all over
And after it's complete I can sell my RB25DE engine, ECU, and wiring - to recoupe some of the costs.
Sure a RB30DET would be nice, but when I added it all up (doing it properly and not dodgy) it was going to cost in the region of $8000 - (RB30 bottom end with forged pistons and balanced internals, turbo + manifold, dump/front pipe, intercooler + piping, blowoff valve, fuel pump, aftermarket computer to run the larger injectors). And with the RB30DET putting out so much torque, it would surely destroy my clutch and gearbox.
I am envious though Joel, if I could justify throwing the money at a RB30 conversion, I would have. But at the end of the day the RB25DET made far more sense.
Ryno
It is a bit of a bummer if you don't have turbo to start off with.
I'd just bolt up the turbo bits to the NA with its decent compression ratio it should go well, better than a similiar modded T.
I think go to pieces might be more accurate... :P the high compression ratio would put way to much strain on the internals, or so im told. I think there were some posts earlier on in this thread about the addition of a turbo to a N/A engine... ill have to check though...
All comes down to how much power do you want to make. Be it now or later down the track.
Its a bit of a waste of money to buy a RB25DET if you are only going to rebuild it with stronger internals, different turbo,injectors, I think this is where the RB30DET begins to become better value for money.
It can also depends how much your willing to pay extra to have a freshly rebuilt engine.
Work out the $$, the pros & cons then make a decision.
I've always liked cubes. :D
Comparing the RB25 to the RB20, 500cc's makes a hell of a difference.
While your spooling i'll be short shifting down the road. :)
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
