hey guys im havin some problems diagnosing whats causing my car to play up.
ill list what is happening and what i have checked.
problems: constant whit/blue somke out the exhaust.
wont hold/make max boost
miss firing
motor fluds with oil when gets hot.
when i took the intake pipe off the turbo there was oil all over the inside all the way to the pod filter
goes through alot of oil.
things i have checked: no shaft play in turbo
just disconnected the oil catch can and put it back to standard to check.
called hypergear to ask about it all and they suggested the the catch can bisso because of the turbo not havin shaft play so they dont think its a oil seal but thats what the previous owner said it was.
the turbo is a garret t04 hyflowed with bigger wheels.
would be much appreciated for a few suggestions to try out. cheers guys
Edited by fat_stag
Well. I don't felt the right to charge you $440 to replace some thing that doesn't require to be done.
Your engine's leaking oil all over the places not just the turbo.
So get you engine oil, catch can and all other issues fixed fist. We will have a look at your turbo if its still making blue smoke by then.
Can you elaborate on "motor fluds with oil when gets hot". What do you exactly mean by this? What oil is in the vehicle and when did this start happening? Did you do something the last few days before this started happening?
how did you install the catch can?
once had a perfectly good turbo shit a seal because a catch can got installed with no breather, 2 outlets on the rockers to 2 inlets on the catch can and no breather anywhere lol... insta-goodbye T28BB :)
was there a way for your catch can setup to breathe properly? or have you made a similar faux pas
Well once you clear breathers and fix other issues to allow oil drain back into the sump, the turbo will stop smoking.
In most of cases If the turbo's got no shaft play and leak oil through both seals its means there is a oil drainage problem. Once fixed the turbo stops smoke. No need to pay $$$ and overhaul a good turbo.
in my case the catch can was only connected wrong for a total of 30 seconds, and the car would drop its sump out the exhaust from milperra to ramsgate it was spewing out oil so bad... irreversable damage to the seals.
this could be the case here, yet yes agreed with hypergear, trial and error try fix whats blocking up if there is and go from there.
Is your PCV blocked by chance?
I had a smoke issue with my RB25 when i had it set up with a blocked PCV valve catch can setup.
Put the stock PCV valve back in, and it went away and never came back.
Only issue is being at idle i can occasionally get rev fluctuation due to the atmo venting breathers.
(because the pvc is connected and gets a bit of un AFM'd air via the breathers :) )
yea cheers guys for the tips and sorry stao i hope you didnt take any of this as badmouthing you i was just sayin what ya said and what my mate said. yea i also couldnt hear ya propperly over the phone because i had shit service and a bit of wind around me. will check all the lines from turbo for blockage's and might just get a new catch can to eliminate that as i issue but the one i got has a breather. also ill get onto a compresion test to see how that is. who knows could also be sparkplugs gunked up from having oil goin through there thats causing the missing. thanks heaps again for the help and ill be in contact with ya stao if all this dont work.
Edited by fat_stag
have you done a compression test? I think you've got a busted ring land.
I am in agreeance with you there..
if you can pull the turbo off...if the exhaust manifold is full off sludge then its rebuild time. or the easier way would be to get a comp and leak-down test done.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
