hey guys im havin some problems diagnosing whats causing my car to play up.
ill list what is happening and what i have checked.
problems: constant whit/blue somke out the exhaust.
wont hold/make max boost
miss firing
motor fluds with oil when gets hot.
when i took the intake pipe off the turbo there was oil all over the inside all the way to the pod filter
goes through alot of oil.
things i have checked: no shaft play in turbo
just disconnected the oil catch can and put it back to standard to check.
called hypergear to ask about it all and they suggested the the catch can bisso because of the turbo not havin shaft play so they dont think its a oil seal but thats what the previous owner said it was.
the turbo is a garret t04 hyflowed with bigger wheels.
would be much appreciated for a few suggestions to try out. cheers guys
Edited by fat_stag
Well. I don't felt the right to charge you $440 to replace some thing that doesn't require to be done.
Your engine's leaking oil all over the places not just the turbo.
So get you engine oil, catch can and all other issues fixed fist. We will have a look at your turbo if its still making blue smoke by then.
Can you elaborate on "motor fluds with oil when gets hot". What do you exactly mean by this? What oil is in the vehicle and when did this start happening? Did you do something the last few days before this started happening?
how did you install the catch can?
once had a perfectly good turbo shit a seal because a catch can got installed with no breather, 2 outlets on the rockers to 2 inlets on the catch can and no breather anywhere lol... insta-goodbye T28BB :)
was there a way for your catch can setup to breathe properly? or have you made a similar faux pas
Well once you clear breathers and fix other issues to allow oil drain back into the sump, the turbo will stop smoking.
In most of cases If the turbo's got no shaft play and leak oil through both seals its means there is a oil drainage problem. Once fixed the turbo stops smoke. No need to pay $$$ and overhaul a good turbo.
in my case the catch can was only connected wrong for a total of 30 seconds, and the car would drop its sump out the exhaust from milperra to ramsgate it was spewing out oil so bad... irreversable damage to the seals.
this could be the case here, yet yes agreed with hypergear, trial and error try fix whats blocking up if there is and go from there.
Is your PCV blocked by chance?
I had a smoke issue with my RB25 when i had it set up with a blocked PCV valve catch can setup.
Put the stock PCV valve back in, and it went away and never came back.
Only issue is being at idle i can occasionally get rev fluctuation due to the atmo venting breathers.
(because the pvc is connected and gets a bit of un AFM'd air via the breathers :) )
yea cheers guys for the tips and sorry stao i hope you didnt take any of this as badmouthing you i was just sayin what ya said and what my mate said. yea i also couldnt hear ya propperly over the phone because i had shit service and a bit of wind around me. will check all the lines from turbo for blockage's and might just get a new catch can to eliminate that as i issue but the one i got has a breather. also ill get onto a compresion test to see how that is. who knows could also be sparkplugs gunked up from having oil goin through there thats causing the missing. thanks heaps again for the help and ill be in contact with ya stao if all this dont work.
Edited by fat_stag
have you done a compression test? I think you've got a busted ring land.
I am in agreeance with you there..
if you can pull the turbo off...if the exhaust manifold is full off sludge then its rebuild time. or the easier way would be to get a comp and leak-down test done.
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
