I have the spec sheet and it specifically mentions ULP (98 octane) in a ratio of 15% to 85% ethanol. It also contains 9mg/L of corrosion inhibitor and green dye.
I can happily email this spec sheet to anyone who is interested.
Trent how much are you charging per ltr? Is it available only by the drum? Very interested in how things go with this. Are you charging the same price per hour for an E85 tune as for a 'normal' tune?
At the moment, we are only selling it in a 200L drum, but I am sure we will be able to sell smaller quantities if you bring your own drum for us to fill up.
As for dyno rates, yes there is no difference in price (that goes for 98 octane, tol/98, E85, C16 etc, its always the same rate). If you want an estimate on a tune, just PM me. I might even throw in some free e85! :action-smiley-069:
Yes I need a definitive answer on the other 15% as I have a map on my Motec M400 tuned specifically for ELF branded E85 which is 15% 98 octane, everytime, doesn't differ per barrel.
I answered this in a prev post, just wanted to say I would definitely suggest a power run if you change fuel brand. Better to be same! If you buy a 200L e85 from us, I will throw in the power run to make sure your tune is safe.
Is there any information on how long will the fuel last before going off once opened? Ie if I buy a 200l drum and use it over a 3-6 month period...
Cheers
Michael
Hey Michael,
The thing to make sure is that it is always in a sealed container. This will allow the fuel to create its own atmosphere and will stop it absorbing moisture. What I do with my fuel is keep it in a sealed 200L drum until I get down to about 100L, then I put that into 5x 20L drums, to reduce the space above the fuel. It has a very long shelf life, so I would think you could easily keep it like this for 12+months.
Cheers
Michael
I've had E85 stored in 200L after opening for over 12 months before, didn't seem to have any affect
As for dyno rates, yes there is no difference in price (that goes for 98 octane, tol/98, E85, C16 etc, its always the same rate). If you want an estimate on a tune, just PM me. I might even throw in some free e85! :thumbsup:
The CSR E85 is the best on the market, I know people who have used ELF E85 and CSR E85 - Everyone is saying CSR gives a better result and has added protection with a corrosion inhibitor.
G'day Brett, welcome to the forums mate.
Gday, the other 15% is Caltex Vortex Premium 98.
Caltex has been proven in a couple of different tests to be the best 98 on the market.
Edited by DiRTgarage
Ive recently learned that Mercury Motorsport has been appointed the official QLD distributor for CSR E85. Trent informed me during a brief chat at the track the other day he has scored the ditribution rights for this fuel in QLD. This is exactly the same fuel as is being currenlty used by AVESCO in the V8 supercar series. Trent is about to recieve the first delivery of the new fuel and is keen to show some back to back tests against not only regular unleaded but also some of the more expensive race fuels.
Im keen to see some results.
awsome
  • 3 weeks later...
I saw the data sheet and indeed it is, alot of the cheaper E85 mixes are using 91 octane for the other 15% so thats good to hear.
Will hopefully be buying some drums in the near future :)
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
