hi all it seems like i've snapped the connection to the plate on the firewall on the clutch assembly on my 32 gtst so the clutch pedal is over the shop so it wont engage. apprently is a common fault. had alook and cant work out how to take the whole plate and clutch assembly out. any instruction/advice or experience would be greatly appreciated. is it normal to just weld it back on?
hey mate, had this happen to me just recently as well tho i was lucky the whole thing didnt come off completely and hold the assembly on with a coat hanger while getting it fixed (dont do this, not recommended but had no choice since its my daily driver). what the problem was, one of your spotwelds on the bracket might have snapped, a common problem if you have a heavy duty clutch or any clutch that has higher clamping force than standard. cheapest solution is to get it rewelded around the spotwelds and add a bit more weld to reinforce it on the way which is what i did. becareful where you weld or the material will get in the way when reinstalling back to the firewall. but if your willing to spend a bit more, the nismo solution as Elite racing mentioned is the best way to go as it doesnt cost much more than da factory one ($110 quoted for standard Nissan).
The assembly is held in by the same 3 bolts that hold the clutch master cylinder in place, and a bolt up behind the instrument panel (I found it easiest to remove the instrument panel to get at that one).
You shouldn't need to remove the instrument panel. A 9-12 inch 3/8 drive extension and 12mm socket should get it quite easily from underneath. You just have to worm it past a couple of wires.
But as said above. That one and the two that hold the clutch master cylinder on and it's away. Leave the pedal in place as it's gonna come out with the rest of it.
I recommend getting the Nismo one as it might save you a couple of dollars to get it welded but I have found that in around 50% of the time the metal will crack again within 12 months right next to where it was welded. It's much better to replace it with the already reinforced one and then forget about it.
Contact Link International on 07 3382 5000.
They are in Brisbane. Or I think Unique Auto Sports is the Nismo dealer down south.
Part number for R32 is - N-46550-RS580 Retail price is $148 but depending on who you buy it from, you can get them cheaper. They keep them on the shelf usually.
Hey guys,
Think this is whats happened to me... Except i am leaking transmission fluid from under the car... Car starts and i can put it in gear when the car is off but cant when it is turned on.... Its parked under my workplace and i need to get it out! any temp fix to get it moving back home?
I have turned the car off put it in gear then tried to turn it back on but it wouldnt turn on
Any help is appreciated
Cheers!
Hey guys,
Cheers!
Yes, you need to replace the clutch slave cylinder and/or the master cylinder. Considering there is fluid under the car, I would start with the slave cylinder.
Ring Nissan and buy it genuine. They cost around $100 for the R33 one. Dunno what the 32 one costs.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
