To answer the initial Q - No, you do not need to change the manifold, it is a waste of money.
The stock manifold runs into issues around the 300rwkw-320rwkw region, which is basically when you rebuild the motor :)
If you are below that, stock motor etc etc save your pennies. You aren't going to get gains to justfiy the costs.
To the others asking about lowmounts and piping - of course it will change. There won't be one manifold that will be direct replacement.
I have the same thoughts on the RB30, I realise you should go a bigger turbo, but I'd be keen to see how it goes with the GTRS. Surely even being chocked up it won't make less power than my RB25, but with a heap more torque low down.
What you'll probably find is the car feels lifeless about 6500rpm because the turbo is running out of puff and the rear housing is making a mess of the situation as well.
So while it'll come on earlier, don't expect it to hold until 7000-7500rpm. You'll be looking to grab gears much sooner.
there is a new style coming out that i have been waiting for over 7 months better collector and bigger runners,i have been in contact with the man who has built it and will be selling it soon,unfortunately the company he got to make it has sold the design to many other shops,his will be sold made from 321 S/S 3mm the copies will be made from 303 S/S 2mm,hpi will also be selling his manifold at a huge price,
here is a pic of the copied one.
by the way this is direct replacement.
Edited by WARLORD
It's a shame you can't get it in steam pipe (like the 6Boost manifold). Any idea what the 3mm 321 S/S will sell for?
nothing wrong with 321 s/s,they don't crack like 304 sus.they will be about $720 (depending on us dollar) delivered in Australia to the door.ill be getting one of the first and testing it on my set up.
Edited by WARLORD
I can't believe people are seriously considering these manifolds. I ran a chinese version of the hpi manifold pictured on p1 years back on an rb20/td06 set-up. After chasing my tail for a few months wondering why it wasn't making any power I came to my senses and stuck the stock manifold back on - and instantly found 60+ rwhp.
Lucky you... How long before we will get to hear your results?
The worst part is they are charging $1700 for it, but its without question from a China factory, costing $300 :P
in a few months as im still part hunting
i have most things just need a baffled sump from somewhere,and a few little things, and some more cash...lol
but as soon as i get the result im looking for ill post it up.
Edited by WARLORD
the main reason manifolds crack is due to the exhaust system not being supported properly, and if my memory serves me properly from tafedays... 304 is more durable for exhaust manifolds, due to the propertys in 321 its more prone to heat stress cracks as its a harder metal
in saying that tho i've always used 304 for all my exhaust work but i havent made a manifold out of it as steam pipe is cheaper and holds the heat in better but not once have i had any 304 crack on me its all in the mounting brackets and flex joints help.
Edited by Cartman
funny the guy who makes them in japan said the opposite about 304 being the lesser material than 321 as 321 has a much higher heat resistance.
of the net
321 is the grade of choice for applications in the temperature range of up to about 900°C, combining high strength, resistance to scaling and phase stability with resistance to subsequent aqueous corrosion.
Grade 304 is more readily available in most product forms, and so is generally used in preference to 321 if the requirement is simply for resistance to intergranular corrosion after welding. However 304 has lower hot strength than 321 and so is not the best choice if the requirement is resistance to an operating environment over about 500°C
more info http://www.viperalley.com/forum/viper-disc...-stainless.html
Edited by WARLORD
of the net
has been a long time since i got taught all that shit, but i use 304 for everything and have never once had it crack, i'll be making a turbo manifold soon for one of my own cars providing i can get the bends cheap enough i'll test it out, could get scary pricing up 20 or so bends in small sizes but will see how it goes when ever i get around to doin it
Was looking at exhuast manifolds and was looking at this hpi one at just jap priced for 1700 which says it keeps the exact stock postion. Now my question is is this a worthwhile to consider getting considering I got the usual mods turbo injectors ecu etc. 270kw , How much more benifet could I receive over the stock manifold?
shit design. if you want a j-spec brand get HKS
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
