iv had a smash in my r32 gtst type m, hit a kangaroo, smashed the shit out of the bonnet.. ive been wanting to put a gtr bonnet and grille on for ages so now i have an excuse! =D
If i was to put the bonnet on will it fit direct n sit flush with the gtst gards or will i also need gtr gards??
https://www.sau.com.au/forums/topic/304527-r32-gtst-with-gtr-bonnet/
The only bits you need are the bonnet, bonnet latch and the latch support panel. My car already had GTR headlights so my grill just clipped on.
Edited by DSTROY
oh.. i thought the gtr bonnets sit abit further up than the gtst's?
No its a perfect straight swap with the hinges. but you will need the folded metal upright that bolts i think from the radiator support rail to the bottom of the radiator. If you don't know what i'm talking about then pop your bonnet and it is the thing that the bonnet latch & horns bolt to. You just remove everything from it and bolt it up to the gtr one. You may need to undo the plastic splash tray under the car (if it still has one) to obtain easier access to the lower bolt. You may need to mount the horns facing the other way and bend the latch down in a vice or something to clear the gtr grill. Well i did anyway. If you can't find a gtr bonnet that comes with the upright then haggle on price because its not worth as much on the market IMO.
oh. cool thanks for that. i always thought it was the hinges that needed changing. haha, atleast i know now. thanks.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
