Tein Ra Coilovers 32, 33 Gtr
TEIN Racing Spec Type-RA
Bought these for my 34 GT but they do not fit
These coilovers were set up for Nissan Skyline GT-R R33 (BCNR33) but will also fit R33 GTS-4 model and should go into R32 and R34 GT-R without too much trouble. You can see from the photos that the condition is outstanding for used suspension. They were obviously not fitted to a car for very long so they are almost as good as new.
For sale is exactly what you see in the photos including coilover shocks, strut tops, bump stops, dust covers, mounting bolts, adjustable spring mounts, damper adjusters, etc (there are no springs included with this set)
$600 will post at buyers expense items located in Adelaide
Contact via pm or phone on 0433348748
info on tein RA as posted on website
  • Type RA TEIN suspension has adapted into its package, the specifications used in the rally field such as the World Rally Championship. TEIN has constructed a footwork for you which gives priority to function.
  • A high grade specification which gives you an unsurpassed drive feel.
  • Introduction of specifications used at competition levels.
  • Adopted a single rod structure for better reception between driver and road surface.
  • A linear damping effect which adapts to even the smallest road surface abnormality by adapting the single rod structure.
  • Seamless tube using a drawing method. Processing technology which enables a high level of precision up to 1/100mm of the inner diameter. Inner surface precision up to 3.2S (inner surface bumps within +/- 1.6 micrometer)
  • Use of ultra light and strong aluminum - A7050 which is also used in airplanes.
  • A I.D.45 piston which is maximum for marketed cars' shock absorber.
  • A different diameter multi-level valve structure which enables damping effect and specifications adjustment.
  • The damping effect adjustment structure uses an evolved version of the special shaped needle valve which has already been proven in the HA/NA dampers.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
