Hoping someone may be able to help us out
just got my new motor going forged internals big sump etc. etc.
Head was checked out and setup to run my Tomei poncams I had used previously
Now its running and all seems happyish
except only seeing -35 kpa vac at idle (factory spec -65 kpa)
this on the stock gauge appears as the mark half way to -700 mmHg (factory spec should be -480 mmHg)
would love to know what others with poncams are seeing
cams will obviously effect vacume at idle but this seems a bit excessive
have checked and cant seem to find any other vac leaks???????????????
any assistance apreciated
https://www.sau.com.au/forums/topic/304566-rb26-vacuum-at-idle/
Yeh cams will affect vacuum, wats the duration and lift of these cams?
also double, triple, and quadruple check your intake side, for vacuum leaks. Im fighting a leak right now, and its a prick of a thing.
but id say its just the cams. does it rev and idle ok?
if it pops, farts and stumbles when you rev it, thatll be a vacuum leak, otherwise, its the cams.
thanks for the replys
car runs well idle is a bit up'n down 900ish to maybe as high as 1000 rpm
but seems to be reasonably steady round 950ish once properly warm
car is not making much power though at really small throttle openings
eg trying to get up a steep driveway
new motor and new twin plate OS Giken so a new learning curve I spose as well
Have not done a real tuning run for power yet just checked afr's etc and loaded it up for a bit on the dyno
need rego next to put some km's on it
Am hoping once i get the cam timing done an a proper power tune it will be better
edit: poncams so 264 9.6 on both (if memory serves me right)
Edited by noone
sorry man i dont have much experience with 26s... ill just say that in advance lol
stock duration is 240 deg IIRC so youve got an increase of 15deg there, should shift your powerband up a fair bit, but i cant see it having that much of a drastic affect of your idle, the overlap wouldnt be THAT major. compared to say, the 285s that some people use. in theory, if 265s cause you to loose that much idle vacuum, a car with 285s would barely idle sub 1000rpm!
but
that is a classic symptom of a vacuum leak on a MAF sensored car. try spraying carb cleaner/aero start around the intake manifold, and if your idle changes or your misfire etc, youve found your vacuum leak.
i guess you're gonna have to hear from another 26 owner as to the vacuum they see...
do you still have the ITBs?
Yeah ITB's am wondering if I still have a leak the cams are not that big
tried some carby cleaner but no real joy
After reading bout your drama with injector o-rings will try n blast some aerostart or somesuch
around there an see if that shows anything up
yeh that fkn o-ring was my problem... prick of a thing to get to on my car, entire top half of the intake manifold needs to come off to get to the fuel rail (like half an hour job even though ive done it like 10 times now)
good luck bro, hope ya get it sorted. darwin needs more GTR love on the streets lol
Well you have a problem, and you know what's likely causing it...
The setup by your own admission isn't even done yet.
Its very hard to say what is wrong or right, if you've yet to sort it all out...
Side note - you may well find the driveway issue won't go away. Part and parcel of larger cams.
These cams are not exactly new to me
Ran they in my last motor as stated in the first post
though had cam timing sorted on install so I spose without cam gears adjusted they might be that doughy down low
but I doubt it
Basic setup has been done, just not power tune :)
afrs etc looked fine tuner didnt really notice anything amiss till he did a lap of the block
to make sure no drivability issues, an there it was, along with an oil leak from the cam cover half moon seal
Appreciate the help though guys
Darwin definitely needs more GTR's
    • Definitely needs a hard top
    • Nah, shouldn't have made any difference. Reds on, or car running, should be same same for what you were doing.
    • Should be able to source 200 cell R32 cat... unsure how easy it would be to get it to Malta though.
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
