Annoying problem that's crept itself up, on very very light throttle, the engine stutters a little, like, super light throttle (1k-1.5k~ or so RPM while in neutral) - it's not the throttle cable either because it does it when you manually give it throttle off the throttle body.
Any ideas?
Giving it a tad more throttle and it's no problems. It just makes the ride really jerky sometimes when driving in like 2nd gear at low throttle. It's an RB25DET throttle body (S2)
Cheers.
https://www.sau.com.au/forums/topic/304572-light-throttle-issues/
Sounds like its running lean there, possibly due to the airflow meter being dirty. Give it a clean first with a can of CRC airflow meter cleaner and see if that fixes the issue first.
Cheers, I don't have any CRC AFM cleaner, will something like Isopropyl Alcohol work?
Yup, isoprophyl alc is good, absorbs water & leaves no residue, also check plugs for gaps, & coilpacks for moisture & crap that will make things (sparks) track. give the coilpaks a wash with the iso & spray with a silicon inhibitor. Quote gospel from PI #116
Cheers GW
are you using an aftermarket ECU?
add some more accel enrichment and see how you go
Nah, just a standard chipped ECU, it hasn't always been an issue and just seems to be intermittent, it barely did it at all on the way to work this morning. I'm still at work though so haven't tried the cleaning stuff yet.
FULL RABBIT OR NO RABBIT!!!!!! noone likes a tortoise, light throttle is for wimps.
Haha, unfortunately that doesn't work so well in peak traffic :(
Plus, I wish my car had a lawnmower style throttle instead of an accelerator pedal :P:D
ok so you want it fixed then.
afm or sticky butterfly would be a good place to start... get out with some carby cleaner.
slight vacuum leak.
dodgy injector, may be spraying to much or dribbling out and flooding one cylinder or not spraying enough due to blockage and running lean in one cylinder.
dodgy plug, same as dodgy injector but different.
Well I just sprayed the AFM and all the coilpacks with iso alc - left it for a bit to dry then fired her up, it was doing the up n down up n down up n down revs at low throttle still but only for like 10 secs, from then on it seemed all good.
I didn't have any long sockets for the spark plugs but will find some if it happens again over the next few days.
Cheers guys.
Changed the spark plugs, no difference - thought I wanted to change them anyway :) (and only $20NZD for the set, can't go wrong)
Until on my way home, hit a little boost and FSHHHHH, the silicone joiner between the turbo and the intercooler piping blows off.
I have a feeling this has been the problem all along, leaking out of top of this joiner.
Gotta try my best to get it on real good tomorrow morning, will post back results.
good work man... that will do it. hope its all good.
Yeah cheers, I tried my best but I think my hose clamps are being shit as well as the 90 degree silicone bend.
Getting a 90 degree stainless welded onto the end of the intercooler piping to eliminate the 90 degree silicone bend and put a straight silicone joiner between the turbo and IC piping instead.
Actually works out to be similar price in the end anyway, just a little more hassle but becomes better off in the long run.
Going to get a new hose clamp as well to replace the one that I think is no good.
Will post back results tomorrow night ;)
Just f**ked around with hose clamps and shit just to see if I can have it running a bit nicer for tomorrows driving.
Started the car up, idling like f**kin' shit, hunting up and down, getting worse and worse and then stalling.
'f**k this' I think to myself, get in the car and just go for a wicked thrash.
Park back up again, idling like a f**kin' dream and not being gay on low throttle, WTF!
So see what happens tomorrow morning on the way to work! - Still going to replace the silicone 90 degree with stainless steel though.
What AFM are you running? It might have the dreaded bad solder joints on the board inside.
It's an RB25DET S2 AFM, I have a 300ZX AFM here ready to go in whenever I can get the car tuned/chipped.
Is it something that I can fix myself? Or if I open it up will it be easily spotted?
Cheers.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
