R32 GTST owners - Did you know...
TTT
 Share
  • 8 months later...
has anyone found out if this is actually possible with the r33 rb25det pfc on the r32 rb20det??? I'd love to know if its true or myth!
Cheers
I have the datalogit software for RB25det which covers the following PFC's
RB20DET
RB25DET
RB251PRO
The interface and software are the same but the maps are not. So if you think you can just plug it in and away you go you would be wrong. You will need the default map to start with in a RB20DET which would be different to the Default map for a RB25DET
I may test this out soon ppls.
The RB30DET won't run on the stock RB20DET maps, I assume this is due to the head being a RB25 (bigger valves/ports etc).
From what I've heard the RB25DET ECU will run the RB30DET with no problems.
All I have to do now is try to find some one with a R33 PowerFC willing to do the test.
Does that mean it would be fine, as long as you tuned it carefully straight away?
If true, this would be great news, as the R32 Gtst PFC is still worth about $2000 new. (compared to R33 at about $1100)
Id say you will need the default's which the RB20DET PFC comes with for it to work. There is more to a PFC than just Ign & Inj map's. If we can get a R32 PFC on a datalogit laptop and then save the default's and use them in a R33 PFC on a R32 in theory this should work. Although if you ever needed to do a PFC reset the maps would default back to R33.
Be interested to see if SK has anything to add to this thread.
I was looking on nengun and greenline they're about 1300-1400approx landed. Thats the AP engineering model (low impedence injectors only), only the ECU, no hand controller.
But if the r33 works, it makes things heaps easier, since theres more floatin around.
If you look at the pins on the R33 ECU a few of them dont match the R32 wiring, so there is definitely a need to fiddle with wiring to get it working. If it woks, but i suspect it can be made to work, but not positive
Or in this case troy
I guess that means the ECU's have different looms and I would'nt fark with it.. If you blow a PFC, $2000 for the specific model would of seemed a sweet deal
I had a hang up that i wanted to use the Pro which isnt available with the R32 so looked into it.
But some things to consider,
For:
- injectors same impedence
- coil packs are interchangeable between engines
- both from the same RB family
However:
- its a big assumption to assume that things like water temp, idle control valves etc are all 0-5V or same resistances and therefore compatible
- some of the injector pins dont match up in the plugs but majority of wires do.
If an R33 owner went RB30 it would be interesting to see them have a play with a re-mappable R32 ECU in their car, if a bit of a play means you can tune the RB20 ecu to run it then i would be more confident in plugging in the $1500 Pfc into an R32 and seeing what works/how it works
hehe Series 1 R33's used a PTU to control ignition, series 1.5 and Series 2 had the PTU included in the ECU... now... RB20's don't have VVT like later model RB25's... do the maths, its not simple just plugging in a Rb25 Power FC.
However, if one was to trick the power FC into thinkiing it was running a really early model RB25DET then that should work just fine. End result... its a lot easier to find and buy an AP engineering power fc anyways.
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
