R32 GTST owners - Did you know...
TTT
 Share
Haha, the funniest thing in that thread is the guy saying that his Haltech was plug and play because it was installed in under 3 hours. If that's true, then my FMIC was plug and play too because it was installed in under 3 hours as well.
And so was my front facing plenum, my previous S-AFC (hell, that was less than *2* hours including wire splicing), and my 550cc injectors will also be plug and play :) Jeebus, my whole car was plug and play! All those mods aren't as complicated as I thought :O
hahahahahaha
the haltech is plug and play once you set up the MAP sensor and splice the wiring loom and insert the air temp probe and a hole host of other things..
hahahahaha
Anyway, I think this is big news for R32 GTST owners.
hahahaha Plug & Play hahahaha
It can take less than 3 hour to do alot of things. lmost all Turbo upgrades are from now on to be called 'plug & play'. Actually due to the simplicity of most upgrades I think they are all plug & play. There are a few people on this forum who have had alot of success with their 'plug & play' engine swaps.
FOR SALE - one plug & play RB25det front cut.
i plugged my playstation into my rb20det sil and i remapped the fuel/air ratios. I just used the plug and play Gran Turismo edit. You guys want me to do yours?
On a serious note, if this did actually work and the fabrication wasn't much to take it up to the price of a r32 one then it would be quite handy for rb20det owners. Be good if he gave some more info tho.
Is this thread for real or not, I would have thought with the wide use of the Apex PFC by now someone would have already stumbled onto this "miracle" if it were so easy why would AP engineering need to custom make the PFC to suit rb20det's at such a higher cost. But if it true i'd be totally stoked.
Now who's gonna be the ginney pig to try and post up results. :D
Now who's gonna be the ginney pig to try and post up results. ;)
Thats a good question. Dose it really work? I'm not close to getting my car running to try. I know someone who has a PFC for a RB25.
mase - thanks for you gt3 remap.. i picked up 800hp with the stage 4 turbo, racing cooler, and stage 3 weight loss helped my into the 9s wit simulation tyres. was thinking about racing modification but cant decide any body think i should do it?
Interesting, that sounds very similar to Carlo's "brOtec"...maybe you guys should swap notes
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
