R32 GTST owners - Did you know...
TTT
 Share
Haha, the funniest thing in that thread is the guy saying that his Haltech was plug and play because it was installed in under 3 hours. If that's true, then my FMIC was plug and play too because it was installed in under 3 hours as well.
And so was my front facing plenum, my previous S-AFC (hell, that was less than *2* hours including wire splicing), and my 550cc injectors will also be plug and play :) Jeebus, my whole car was plug and play! All those mods aren't as complicated as I thought :O
hahahahahaha
the haltech is plug and play once you set up the MAP sensor and splice the wiring loom and insert the air temp probe and a hole host of other things..
hahahahaha
Anyway, I think this is big news for R32 GTST owners.
hahahaha Plug & Play hahahaha
It can take less than 3 hour to do alot of things. lmost all Turbo upgrades are from now on to be called 'plug & play'. Actually due to the simplicity of most upgrades I think they are all plug & play. There are a few people on this forum who have had alot of success with their 'plug & play' engine swaps.
FOR SALE - one plug & play RB25det front cut.
i plugged my playstation into my rb20det sil and i remapped the fuel/air ratios. I just used the plug and play Gran Turismo edit. You guys want me to do yours?
On a serious note, if this did actually work and the fabrication wasn't much to take it up to the price of a r32 one then it would be quite handy for rb20det owners. Be good if he gave some more info tho.
Is this thread for real or not, I would have thought with the wide use of the Apex PFC by now someone would have already stumbled onto this "miracle" if it were so easy why would AP engineering need to custom make the PFC to suit rb20det's at such a higher cost. But if it true i'd be totally stoked.
Now who's gonna be the ginney pig to try and post up results. :D
Now who's gonna be the ginney pig to try and post up results. ;)
Thats a good question. Dose it really work? I'm not close to getting my car running to try. I know someone who has a PFC for a RB25.
mase - thanks for you gt3 remap.. i picked up 800hp with the stage 4 turbo, racing cooler, and stage 3 weight loss helped my into the 9s wit simulation tyres. was thinking about racing modification but cant decide any body think i should do it?
Interesting, that sounds very similar to Carlo's "brOtec"...maybe you guys should swap notes
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
