Ask them to check the timing again, (belt missed a tooth)
If it has adjustable cam gear make sure the bolts holding it in place are tight.
Might be an idea to swap the stock intake pipe out for a stronger silicone one.
probably standard size. why do you ask?
purely because you often find with a thicker than stock head gasket you loose some low/mid range. only because of the drop in static C/R.
but if it's standard forget that then. look to the tune, and as others suggested make sure the cams are set and timed properly.
could also just be the dyno... does it actually 'feel' lacking in midrange? maybe run it down the drag strip and see what kind of time and mph it runs, or even just run it up for a power run on someone else's dyno and see what you get.
yes it feels lacking in mid range. big time!
i found the problem, the vct electrical clip was broken and disconnected. i replaced that and hello midrange powah!
trouble is, they tuned it like that. so i expect they wont mind re-tuning it properly now.
thanks everyone for your help and advice!
the people who mentioned vct were right on the ball. the electrical clip for the vct solenoid was broken!
its runs much better now, but will obviously have to be re-tuned. i dont know how they didnt notice this on the dyno though...
Ive seen every stage of your build so that would be a yes :P
HAHA
it lived there for about 3 months! it started as a motor in and out...
and then i bit off more than i could chew and added a turbo, clutch, split dump, $200 cat (which i then gutted in a fit of rage), ecu and bov.
the motor came minus camshafts. but my cams from the blown motor didnt turn in that head. so then i had to find a replacement head, have it machined, new gasket etc.
then we had to get all the water and oil lines for the turbo! the old turbo was oil cooled only, so whoever installed it just hacked off all the water feeds. needless to say, genuine nissan cost a mint.
and after all that, when the car rolled off the dyno at long last... the wastegate actuator fell off on the way home!
and now this vct problem! its been 5 months since my poor baby has been running at 100%.
cant wait until i get a gtr and do it right the first time.
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
