  • Replies 271
Posted Images
Do we have definitive photographers for the day? If so, can we pay them and get all the shots of our cars (hopefully lots) in RAW format or NEF or whatever, sent on a DVD? :)
Would love gorgeous hi-res shots for me to fiddle with to my heart's content...
Do we have definitive photographers for the day? If so, can we pay them and get all the shots of our cars (hopefully lots) in RAW format or NEF or whatever, sent on a DVD? :bunny:
I'll fibd out for you
Theres usually 4/5 pro's there taking pics
Pfft skidz?
Last time i smoked them i got told off! Should be called "Chirp on Sunday"
They just don't like your skids. My skids got me an award at last texi ("Best thrashing" AKA "Cassbo, please use this award as incentive to maintain your car") :D
I'm still trying to find out if Ill be in Sydney, bloody well better be, Ive got my "gotta do a skid" itch going on, trying not to hit the cones whilst doing said skids and getting around the course in a decent time is something that I'm sure will need some work.
hey execs, heads up if there is another payment for texi coming ur way under my user name. the name of the person its for is Andrej Zecevic.
and Doof, can you put him on the list? thanks baby!
Pfft skidz?
Haha
You're a true hoon. Its not "burnouts cause my right foot got stuck sunday" :whistling:
On this topic though, im hoping we can allow screamers here but thats an ongoing debate, ill sms you if that gets approved
Haha
You're a true hoon. Its not "burnouts cause my right foot got stuck sunday" :ermm:
No it's called "That's not a burnout... That's from my turbo seals being blown on Sunday"
hey there,
I'm a mate of MSD-00F's and probably going to come along for this.
Quick question: As far as secondary bonnet restraints are concerned, apparently its in the CAMS rules now that the majority of standard bonnet latches qualify for this because they actually feature two completely independent mechanisms. Mine is definitely like this. The first restraint releases when you pull the lever in the cabin and the second when you lift the little tab at the front of the bonnet. neither one of them affects the operation of the other.
Do you reckon this'll pass scrutineering?? I hear its basically up to whoever's checking it on the day, and they can be lame about it.
Also, "fire extinguisher in reach of driver" or something, would in the passenger foot-well be fine?
Just don't want to get there on the day and be knocked back, raging would ensue..
Cheers!
im unsure about the bonnet latch thingy as im still tryna figure out the same thing for mine :)
but yes the passenger foot-well is the perfect spot for it. most ppl out theirs there.
SEE YA THERE ANDREJ :woot:
At the previous Texi I don't think you needed a secondary (or tertiary as the case may be) restraint to pass scrutineering. I'm sure an official will confirm shortly.
In the event that an extra restraint is required, I have seen many ways that this can be achieved. You can use a belt, a bit of rope or go and make something similar to what I have... 5kfyn9.jpg
As for a fire extinguisher, pretty much any where you can reach from the driver's seat is a good location for it. Mine is located behind the passenger seat
Actually, there is a guide on mounting fire extinguishers. It might be specific to R33s, but it will give a rough idea what you can do :)
http://www.skylinesaustralia.com/forums/in...t&p=4963976
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
