  • Replies 271
Posted Images
doof 5
benm 15
owen 10
matt 30
totalling $60 so far for white!
Hmmm... not bad so far lol
ZOMG LIKE 4 DAYS TO GO TILL TEXI!!!!!!!!!!!!!!!!!!!!!!!!!!!
HELLS TO THE YEAH TO THE SHIZZEH! :(
WOoooot!!! Texi!!!! : :D
this is what i called mixed emotions, happy cos its forecast for sun on Sunday, but sad in the sense there will be no wet t-shirt competition, oh i mean no white t shirt :)
More info from BOM site:
Forecast for Friday
Cloudy. Isolated showers. Winds southeasterly averaging up to 25 km/h.
City CentreShower or two.Min15Max20
PenrithShower or two.Min13Max19
Forecast for Saturday
Cloudy. Areas of rain, easing to isolated showers later in the evening. Winds northeasterly averaging up to 40 km/h tending northeast to northwesterly up to 45 km/h during the morning.
City CentreRain. Windy.Min15Max19
PenrithRain.Min13Max19
Forecast for Sunday
Mostly sunny. Winds west to northwesterly averaging up to 35 km/h tending westerly and light by early evening.
City CentreMostly sunny.Min13Max21
PenrithMostly sunny.Min11Max21
Quick question:
Do we get the Courses on a bit of paper on the day? Or any chance we can get them the night before? I am slightly retarded when it comes to remembering the courses, so i need as much time as possible to have ANY chance of remembering them!!! Cheers
Andy
Quick question:
Andy
Remembering courses is optional.
Ripping skids is mandatory!
HAHAHAHAHaH Yeah i know mate, i just dont want too many of those moments when you go "is it left...no wait its right.... oh crap its left.... ahhh i farked it up!"
That's called a scandinavian moment... If you can pull it off, it's even more impressive then a scando flick!
Whoo!
Only real problems I had with remembering last time was battle courses... the one where it just went back and forth criss cross was just too hektik for me.
Just make it up.... I think I did most of them lol!!!
Mwahaha scando flickehhh is teh awesomenessss :)
How about we give you points for style if you look like you meant to do it that way :)
haha i remember that, and cone relocation services :ermm: i still have a good laugh when i watch that video
Video?? I don't think I've seen this said video :) Nawww lol it is probably somewhere hiding from me...
Cone relocation services are my specialty... Oooooh and my handbrake turns have increased slightly :D
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
