id really appreciate a few questions being answered for me.. any help is better than where im at now.
1. when cornering fast, the "SLIP" light comes on in my r34gtt's dash, at roughly the same time, it feels like fuel is
cut to the engine and momentum is seriously halted, is this the same as the "TCS" off button? which doesnt seem
to stop it? how can i turn this off?
2. hicas light comes on every once in a while, doesnt seem to do anything though.. is this an issue?
3. turbosmart dual stage boost controller doesnt seem to change boost settings, i checked with a multimeter to see if the boost controller was getting the signal to change to high boost when i flick the rocket switch and it is, however boost always stays the same at 0.6 bar. i wound up the high setting a few notches and still no difference, anyone know what could be going on?
4. the tubosmart dsbc (above) is teed into the line between the turbo and wastegate, where it should be.. however
there is a second gated boost controller teed into the line between the intake manifold and a little electronic box
with "boost sender" written on it.. obviously this isnt going to effect boost, so why is it there? simpy to trick the
boost sender with a lower reading?
cheers for the help guys.
ive also just done an epic search and read up on the common slip/tcs problem and will see 666dan re: gizmo to turn tcs off automatically, however, when i press the tcs button, no "tcs off" light comes up on my dash, as it sounds like it should.. is this a problem with the switch or the tcs backlight?
also forgot to add question 5. perhaps the most worrying.
5. when im driving along in 1st, 2nd or 3rd gear and realease the throttle but still in gear, i get this loud scraping noise coming from waht seems like the lhs passenger door, its obviously a mechanical type noise and very hard to explain, like theres sand/gravel traveeling down exhaust after the turbo.. only happens on over-run though. does anyone know what this may be? completely goes away after i press throttle again..
Ok when u have NO TCS light up on ur cluster this means TCS ( Traction controll ) is enabled.... this means if u corner to hard... or slip by any chance.. the car will try help u correct it...to gain traction. this means that u will see SLIP SLIP flashing on ur cluster...
when u press ur TCS button and on ur cluster it says TCS off this means obviously traction controll is off meaning if u slip... its all up to u to gain traction u will not see the SLIP flash on ur cluster while TCS is off..
with respect to the button not working.. maby it is just light problems or maby the system is faulty.. ?
and that gravel noise neva herd anything like it... maby u got rocks in ur zorst lol ? i cant help u with that
cheers
George
start your car.. then press the tcs button.. even if your light isnt on leave it.. then go round your corners and see if traction control still kicking in.. if not then you can prob put it down to dead bulb.. but keep the fast corners off the road eh.. unless your a hero
what are you doing when the hicas comes on or is it just random?
hicas appears to be random, and no, heroics dont belong on streets im well aware of this.
went out last night to double check everything again, and it seems the tcs off button does work as does the backlight as it displays "tcs off" and no fuel cuts around corners.. so thats all sorted, i think i was just worried as im unfamiliar with these cars. however i know enough to know it needs new coils.
does anyone know about question 5? or has anyone experienced similar? i know its weird, but on over-run the car makes what sounds like a sharp buffeting noise from what sounds like the lhs? only at higher revs say above 3000rpm hence why it only seems to do it in 1st 2nd and 3rd..
has got me stumped.
leave the car in neutral and rev past 3k and have someone outside trace it down.. its hard for anyone to diagnose that over the internet without more detail/sound
Edited by .:: GimpS-R34 ::.
    • Took it to all Japan day. Thrashed it all day and it will still drive home. Very very happy man right now
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
