Checked my coolant this morning in the reservior, noticed it has gone down to just past the 'min' level and is discoloured brown.
I had my mech flush and clean out the radiator about 4000 km ago (back in September). Also did water pump.
I'm taking it in for a service in a week anyway.
Just wondered if I need to top it back up for just a week?
I understand that the level shoudn't go down and that this is a sign of a leak, also the brownish colour could be anything from contamination by oil (due to leaking gasket or *gasp* a failing cylinder?), to just corrosion?
If it is corrosion then how is it happening after the radiator was cleaned out and new coolant put in? Or is that normal with a cleaned out radiator?!
https://www.sau.com.au/forums/topic/304651-coolant/
i think it can also happen if it has overheated.
Car hasn't been tracked or dragged, have never seen the temp sensor go more than half-way.
Don't give the car much of a thrashing. Occasionally give it WOT but only up to the speed limit.
Stock boost BTW, but has FMIC.
Edited by Tony de Wonderful
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5044200
the problem with the stock gauge is that it sits at normal from around 70 or 75 degrees all the way up to around 100 or 105 degrees. and then it will suddenly jump up from there.
and a car doesn't have to be tracked or dragged to run hot. often they can get hotter sitting in traffic than out on a track where there is plenty of air flowing through the radiator.
it could also be that you have done a headgasket, as oil in the water or water in the oil doesn't always occur. but best to speak to your mechanic about it.
just a thought, but was the coolant that he put in green? i have seen some redish coloured coolants before (i think repco do one) so if you hadn't taken any notice of the colour until now it may be that he just used a different colour coolant and there is no problem at all
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5044385
I think the coolant was green.
Engine still seems to run smooth and not aware of any smoke etc from 'zaust.
I took the cap off the radiator and the coolant residue inside seems fairly 'clean'. Coolant was not sitting flush to the top of the radiator...is it supposed to? Oil level seemed ok also, no sign of gung or stuff on the dipstick except 'normal' engine oil.
I noticed on my reserviour there is a kind of 'vent' on top (see pixxor)? Is it possible that it (the coolant) just evaporated away and left behind a bit of concentrated gung at the bottom of the reservoir?
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5044542
In my experience, alot of coolants will go brown if they have been exposed to air.
When your mechanic did the coolant, did he bleed the air out of the system with the bleed bolt on the drivers side top front of the motor? its near the front of the fuel rail and has a sticker around it with some jap writing on it. At least thats how it is on the RB26.
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5048875
I opened the radiator cap and it took about two cups of water to fill it up. When I opened it up next day the level had gone down a little, so I figure there is a tiny leak some place.
Spoke to my mechanic and gonna bring it in next week. In the mean time he said just keep an eye on the water level and be careful.
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5049669
Q. And what do the words ^^^ "be careful" mean?
A. As mad082 said in post #4, the temp can all of a sudden, race up to the red. Watch the gauge like a hawk. Personally I wouldn't drive it now if there are spare wheels hanging around.
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5050135
Well I am making sure it is full before I drive the car. If it has a very tiny leak, is it likely to catastropically turn into a bigger one just like that? I mean any engine could suffer a complete loss of coolant I think?
Yeah need the car for work.
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5050189
depends on what is causing the leak. if it is in the radiator core itself then it may not get worse at all or it could let go and dump all the coolant in a matter of seconds.
if it is in the head then the same applies. i have seen some pretty big holes in water galleries in the past. my aunty in law had a festiva with a hole the size of a golf ball.
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5050255
Well I took it to the shop and they checked it for leaks...with the result that they could not find any.
Mech reckons there may have been an air bubble or something from when the coolant was last changed.
Level seems stable now but keeping an eye on it.
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5063388
Which mechanic did you take it to? I've bled my car up 3 times in 9 months (Dont ask!! Lol) and every time managed to get every drop of air out. Shouldnt be too hard...
Probably shouldn't say, but I am assuming they used one of their junior guys to do it. No harm done really.
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5063430
  • 1 month later...
From my experience - it takes half a week to fully "burp" the system of air.
1 Drain the radiator.
2 Fill it up to the brim.
3 Fill up the over flow bottle to just over the max level marking.
4 Drive the car like normal - DO NOT give the engine a hard time - take it easy.
5 Let engine cool (I usually wait till next morning).
6 You will notice the coolant levels in the over flow reservoir drop quite considerably.
7 Open radiator cap - GENTLY SQUEEZE the lower radiator hose and then the top radiator hose - you will notice quite alot of bubbles coming out - the radiator level will then go lower - this is normal.
8 Fill radiator to the brim.
9 Fill up the over flow bottle to the max level marking.
10 Repeat steps 4 to 9 daily until the coolant level in radiator and overflow reservoir stop going lower (For me it took 4 days).
TIP: Keep a bottle of fresh coolant in your boot for 1 week after changing your coolant - this is so that you can top up where ever you are.
https://www.sau.com.au/forums/topic/304651-coolant/#findComment-5140350
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
