meh, $1500 for power fc + tuning or ~$1500 for a tuned biki/nisstune
agree'd on the power fc, overpriced for old tech. but i'd be shopping else where if quoted that price for nistune installed and tuned. the boards retail for about $400 then a tune after that. i think the average for a install and tune is around $800.
Edited by QWK32
yeah i was just being generous, its on my list, prob before the +12 offset wheels, bc colilovers, caster bushes, 34 gtt brakes and a fair few other things - being a uni student = constant state of poverty
i recommend trying to get out of it as cheaply as possible mate.i wouldnt spend more than a dollar on it
re-drilled?!? :) lol i hope you mean hi-flowed, which is also an ok option, but at around $100-$150 per injector, it comes to around the same price if not more than a brand new set of something like the Siemens DEKA ones or even Deatschwerks (depending on exchange rate).
a couple of the downsides IMO to hi-flowing are:
- even though its only when you get them, your car is off the road while they are off getting hi-flowed. for people that rely on there stagea as a daily, this is no good.
- unless the hi-flowing process involves replacing the solenoid/actuator, you still have a ~10 year old injector.
Sorry, i have to use the trendy word hi-flowing, so next time i talk about turbos i will remember also to not state what wheels etc they have , i will just use the loose term that covers everything when car people don't actually know what they are talking about - hi-flow. How do you think they make
the injector flow more btw, just curious?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
