Hey guys...
I've had a shitty idle problem in the last few weeks, my car wants to idle around 3 - 3.5k rpm, almost uncontrolled and I'm pretty sure its a vacuum leak as my car is map sensored. I've ruled out everything else, its got a flyby wire throttle and I'm certain its working fine. Noteworthy at this point, THE CAR STILL DRIVES AND BOOSTS FINE, I've seen no drop in power, boost pressure or throttle response/lag. Just the idle is f**ked.
I took it to Nissan today and they did a full check including throttle position relearn, idle air volume relearn etc. and confirmed that it was an air leak in the intake manifold. They sprayed carb cleaner around cyl 2 and the idle dropped and misfired, again confirming the vacuum leak @ that point.
I stripped down the entire intake side of the motor including fuel rail and injectors.
This is what I found o-ring wise: th_P1000709.jpg th_P1000710.jpg
(note the bottom right o-ring - the worst of them all was in cyl 2's intake runner.) (click the pics for larger)
I've got WRX 440cc injectors in, and I installed them some 5 weeks ago, using the stock o-rings, as they are essentially a perfect fit, and the idle problem only came up once every few days, most times it would idle perfectly. However if I just let off the throttle when at high revs, or rev the car in neutral the idle would disappear and it would rev straight to 3k. I had to 'guide' the revs down in gear until i was at like 800 rpm and clutch out, then it would idle fine...
My question is, are the bad O-rings enough to cause a substantial vacuum leak and subsequent idle problem? And why did it not surface until almost 4 weeks after I installed the injectors?
What everyone's thoughts??
thanks.
Cam.
https://www.sau.com.au/forums/topic/304708-bad-injector-o-ring/
those o rings look bad - are they injector/fuel rail o rings? that would cause fuel leak there rather than air leak.
if you haven't looked, check out injector/manifold rubber insulators - it pays to buy new ones, cos i had the same problem, massive leaks at #2, 3 & 5 cylinder.
Was the car running rough?
my car is MAP sensored, so when there's a vacuum leak, instead of running rough like MAF cars, is senses the vac leak like an open throttle, and raises the revs - but if my car was MAF sensored now, i would be idling rough id imagine...
those o-rings were the ones going into the manifold, not into the fuel rail.
new o-rings today... hopefully problem solved.
well regardless of whether or not the o-rings are the source of your problem they 100% need to be replaced so do that first. stick with a set of new genuine ones providing of course they are the right size for your wrx injectors. i would say it should fix your problem, but if it doesn't you'll have to keep hunting. nothing lost though cause those o-rings needed replacing regardless.
No good new guys. I've installed the new o-rings, and STILL no luck.
On first start-up, it was ok... idled fine, normal cold start, but after a minute or so, the revs started to rise, back up to 3000 rpm and now im no further forward.
Its got me completely stumped. Just gonna take it into Hyperdrive (the performance shop) tomorrow and let them have a look at it...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
