I am wondering what the operational differences between 32 GTR and 33 GTR (or GTS4 if that's different to 33 GTR).
Basically, I believe my Stag has a 33 GTS4 setup which runs a 5% preload.
What I think I know:
32R no preload, polls 10x a second
33R/GTS4 5% preload, polls 100x a second
What I would like to know:
Are the sensors all the same between models?
Is the preload mechanical? (built into the clutchpacks) or is it the control unit feeding pressure into the system to maintain the minimum 5% preload?
What I am trying to figure out is, can I swap in a 32R control unit and still have the system operate the same minus the 5% preload?
AFAIK....yes!
the difference is in the pump on the diff and the computers...I am pretty sure that the xfer case is the same.
I have a 32 gtr transfer case in mine.
Cheers for the replies guys, I might try pick up a 32gtr control unit and pump and see how it goes! Cheers :(
elky, I guess if what I want to try works, then that will probably mean what you want to do will work too.. it's not going to happen tomorrow but when I do get around to doing it I will post up whether it works or not ;)
Just a thought, see if there is a residual hydraulic pressure with the 33 module and then with the 32 module.. You don't really want to be throwing it in, thinking it works, but still having some preload if it is the hydraulic pack above the diff that is the difference. *edit - thought you were using the 33 pump.
Also do you know if there are any pinout changes from 32 to 33 modules? Might not be a straight swap.. only thoughts of what if.. I would like a faster reacting attessa myself.
Edited by heller44
Can't answer those questions yet mate :)
I am going to start with my mates 32 GTS4 computer, see if it plugs in. If it does, I'll put car on hoist and put it in gear, see if front wheels spin. If they don't (and I don't get any error codes etc.) then it should be good to go! If the front wheels do spin, then I will look at swapping in a 32 pump and go from there.
Edited by bubba
my old gtr i blew 2 r32 gtr boxes, my 3rd was a 33 box and it wouldnt spin 2nd gear as easy, would just spin and grip up alot more, so im thinking its actually preload on the clutch packs
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
