Where is the best most efficient place to plumb back your bov.
into the front of the turbo or into the exhaust manifold before the turbo?
i cant find many people that have plumbed it back into the exhaust manifold, is there a reason for this?
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/
Before the turbo, but after the Air Flow Meter (AFM) or what ever meters the air on the intake side
(in my case, its the map sensor in my Megasquirt, connected to the intake manifold)
Nigel
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5045353
what looks like when it is plumbed into the manifold is the external wastegate. very similar in design and operation
the outlet of the BOV needs to vent to an un-pressureised section of the piping, if it is venting to a boosted pipe, it aint gonna do too much at all....
How noddle has his is ideal.
Radiator hose is good for connecting to the outlet of the bov too...
BTW noddle, those hose clamps look tough as... where did you source them from? and what DIA pipe are you useing?
i just orded a stack of 2.5 inch, hope its not TOO big
Edited by MAG86
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5045492
external wastegate is plumbed in after the turbo into the exhuasts dump pipe.
what im suggesting is that the vented air from the bov is pushed into the ex manifold so the turbo gets a thrust of air to keep the turbo spooling between changes.
maybe im looking too much into it..
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5045633
what happens if you plumb it back before the afm?
my afm is in my cooler piping after the cooler and before the tb?
i was gonna plumb the bov from between the tb and the afm and throw the air into the front of the turbo.
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5045811
i think that if an extra puff of air went past the AFM off throttle it would lean out to buggery.
i think do it AFTER the afm... and yes close to the turbine to help keep it spinning
BUT if its a big 'dose' of air it may go back through the afm anyway.... good point you have there...
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5045934
Plumbing the BOV into the exhaust manifold IN theory could result in a minor antilag effect, but could(and probably would) cause backfiring due to unburnt gasses receiving a shot of oxygen. the shockwaves inside the manifold would likely sheer the exhaust wheel after a while.
Personally I wouldn't do it, but it could be something to have a play with on a throw away engine...dont use your pride and joy.
cheers
Jason
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5046168
if I read this right, air filter to intake pipe to turbo to cooler (inter-cooler I assume) to afm to pipe to throttle body
If you put the BOV before the afm and vent it to atmosphere it wouldn't upset anything
"i was gonna plumb the bov from between the tb and the afm and throw the air into the front of the turbo."
if you put it after the afm back to the intake of the turbo or vent it, you WILL have issues with metered air (rich)
my suggestion, move the afm before the turbo, have the bov in front of the throttle, back to turbo intake after the afm (between afm and turbo)
draw a picture of it, you will see what I'm saying
Nigel
Edited by noddle
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5046274
i dont fully understand the afm bit, if it gets more air wont it just read it as more air?
its just air.
the more air the afm see, the more fuel it will injected into the engine, ( it only see the air going through it, it has no idea that you have plumbed it into anywhere)
here's a picture, the one with the cross will work, but it will run rich when the BOV opens
Nigel
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5047385
the first diagram is what my mate had with his RB30et we built a few years back. moving the afm to AFTER the cooler was the best thing we did...
and nigel... hose clamp details mate! (your bits are getting packaged over the weekend)
Nubco nubco.com.au
looks like they are only a Tassie Firm, how about that, most of the time it a mainland firm that doesn't have a outlet in Tassie..
but I have seen these types off clamps on the net though
the pipe size is,
Pod to inlet to turbo is 3 inch, turbo to intercooler to throttle body is 2.5 inch, turbo exhaust is 3 inch, no cat, muffler at the end just before it comes out the back
Nigel
Edited by noddle
https://www.sau.com.au/forums/topic/304715-plumb-back-bov/#findComment-5047843
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
