Hi all,
Just wondering how many kilometers some skylines have done out there, and what problems they have run into due to age and fatigue. Would be interesting to know how many 100,000 ks we can expect before any major dramas.
I would have liked to set this up as a poll but not sure how to.
Mine has done 75,000kms with no engine troubles so far.
https://www.sau.com.au/forums/topic/30472-how-many-kms-has-your-car-done/
  • Replies 51
i think this will be impossible to answer due to them being wound back. I wouldnt base the condition of the engine based on kms. It depends on how much its been thrashed and treated. A well maintated rb will last forever
I am pretty sure not all skylines are wound back. I know when I bought mine i had it inspected and the mechanic said the wear and tear on the car matches the kms.
Even if u do look after the engine it is inevitable that someday something mechanical will fail. I am just curious if this has happened to anyone yet due to old age and not from being thrashed. Or will we have to wait another 5-10 years before we start seeing these problems.
Is there anyone who is into several 100,000 kms yet?
I got my R33 at 123,000k's...have gone up to 151,500k's since...still sounds beautiful I must say. But I do watch what oil goes in and put those long life additives and such, just to make sure.
I guess the only thing is that the engine oil probably doesn't usually last 5000kms like it should...may get black a bit earlier, like 4000kms
My 25T has just clicked up 118K. My R32 gtst before that got to 125k before I traded it, still going at 150k according to the current owner. My sisters Rb20e Cefero is now up to 220k and still going strong, starts first time every time and runs smooth as when she got it at 70K.
G
Bought my '95 GTS-T with 54,000km on the clock, i've now got 83,000km on the clock and all i've replaced is the clutch and rear shocks. Apart from that it hasn't missed a single beat, never stalled or anything... superb !
1992 R32 GTR, genuine 71000km's on it, only problem has been a snapped valve guide... it happened quite some time ago (the piece that came off went into a cylinder, scored the top of a piston, and you could tell it was quite old from the carbon buildup on it) but the car was still going happily. Got it fixed when I decided to rebuild the engine.
I think I've been living in Japan too long - I thought my old GTS was well passed it's best when I sold it with 91,000KM on the clock...that's Japanese thinking for you. There was nothing wrong with the car either. Never missed a beat. Trouble is over here, once you start getting close to the 100K mark car lose all re-sale value...:D
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
