I've had a feeling that thermo booster hasn't been kicking in traffic.
I did the short as the workshop manual advises, with no result.
With a multi meter I tested the thermo switch end it had 10.33v
thermo end of the plug shows no voltage.
What shoul I be checking next?
Cheers norm
https://www.sau.com.au/forums/topic/304750-thermo-booster-not-switching-on/
well is your car overheating or what? . turn the air con and the fan should go eventually
no but the increase in temp is alarming. I bypassed that switch to test it, anyway r32 thermo are rad temp based for the thermo not a/c. I have already checked the clutch fan no problems there.
Power up the fan manually from battery power with some wire and see if it runs. Good place to start..
ill test that next but i doubt its the fan, since with the switch bypassed the fan plug end is not howing any voltage
If there is an increase in temp, then there is overheating. How hot is the engine getting when you have A/C working?
What happens when you supply power directly to the fan?
i havent run the ac while driving since it hasnt been regased yet.
i have tested the the fuse plugs with a multi and the trigger switch shorted and that isnt showing voltage
The fan only works when the A/C is on, and the engine starts to overheat. If you aren't running A/C, then the fan isn't going to work.
Thought that the fan was triggered solely by the temp switch in the radiator,
cubes as a diy to put a diode in to trigger it with the a/c
Have wired mine back to the way its sposed to be an can now confirm it is driven by the temp. switch
Still have no A/c at this point so can only assume, an look at the wiring diagram, the A/C has nothing to do with the overheat fan!
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
