R33 Na box up for sale come with r33/r34 shifter, thrust bearing, clutch fork and the box itself.\
great condition just need a slave and your done.
good for those who are doing a manual conversion on there R33/R34 Na of R32 if you dont care about speed cluster. or those with f**ked up gearboxes from to much dori too much of that slapping the stick into 2nd LOL
Reason for selling: was going threw R32 manual convserion when i noticed it have a speed sensor on it (shame) hence why its for sale. exactly identical to the rb20det box except for the electronic speedo which is why im seeling
Price: 350 negoitable or swaps for a rb20det box
Contact: pm me or call 0403 269 349
cheers
Edited by pig 32
https://www.sau.com.au/forums/topic/304767-r33-na-box/
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
