hey guys
im thinking of buying a d jetro for my rb26, just wondering if anyone has installed there nipples while leaving the plenum ect... on? apexi recommend installing them after the throttle bodys, i really dont want to pull off my plenum and throttle bodies, is it possible to leave everything on and do it?
cheers
https://www.sau.com.au/forums/topic/304774-installing-a-d-jetro-on-a-rb26/
hey guys
cheers
I wouldn't leave the plenum section on and try and install the Nipples, You wouldn't risk drilling the holes when its on! Imagine the shavings in there :D
You are gonna have to remove the plenum section 1000% if you go ahead with it...
I have had two D-Jetro computers installed and thats the way they have been done :bunny:
like tony said you should 100% NOT drill the 3rd and 4th runner while still fitted to the car. There is no way you can drill and tap those two holes without getting swarf in the engine.
I have previously been a big fan of doing it properly and installing the 2 nipples in runners 3 and 4 post throttle body as apexi reccomend. some people do the dodge and use one of the post throttle body vacuum lines coming off the little vacuum box and just tee it into 2 feeds for the 2 map sensors. I had previously seen people have problems with that, but lately 1 or 2 have seemed to still work quite well doing it that way.
personally I'd rather do it properly, the downside of course is it's a pretty hefty labour bill to remove and replace throttle bodys etc just to drill and tap 2 holes for the nipples. talk to the bloke tuning it and see what he wants.
check the documentation or ask their local support
there are known compatibility issues with individual throttle bodies and map sensor based ECU's
i believe thats why apexi make you install it in the exact spot on the plenum and not just anyold where
thanks for the replys guys
what if i got a haltech e11v2, where would i tap into? im pretty sure they only have one map sensor? (correct me if im wrong?
thanks
the haltech will work fine off the vacuum balance rail (factory boost gauge port @ the back)
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
