Hi Guys,
I was just wondering if anyone knew where the r32 outside air sensor is located? My A/C is busted and this is what came up in the fault code.
I did some searching and I cant find the sensor or any post's about it.
Any help appreciated.
https://www.sau.com.au/forums/topic/304784-r32-outside-air-sensor/
Hi Guys,
In front of the radiator and from memory it is supported off the bonnet latch support arm. It is a black rectangular unit.
Thanks for the help guys. I found where the sensor should be but it is absent. Where do you get replacment sensors from?
It appears I need the following:
21 - outside air sensor
24 - Intake temperature sensor
25 - Sunload sensor (small sensor on the left hand side of the dashboard near the windscreen)
  • 5 months later...
yea the manual has this to say about the sunload sensor:
"NOTE: If vehicle positioned in dark place or if sunlight is exceptionally strong, then sunload sensor error may be indicated"
so probably best to do the test outside, but not in direct sunlight
i went looking for my outside air temp sensor but i couldnt find it. what i could find was a random plug hanging around the area where everyone says the sensor should be. i took photos of this plug and i'm wondering if someone can tell me if this is the plug that connects to the air temp sensor. if so then i know mine is missing.
i would check nissan fast except my computer with that on it has broken beyond repair the other day.. FML
heres the pics, is this for the air temp sensor??
Edited by jonboy
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
