what type of lip is it? mine was cut and a lip was stuck on with screws inside the engine bay... some people actually though mine was original aswell lol
Same. Only when you lift a genuine gtr bonnet do you realise how much difference there is.
https://www.sau.com.au/forums/topic/304799-gtr-bonnet-lip/#findComment-5051596
i know its not really topic related. but im about to do the same thing. can you post up pictures of the bonnet you cut to make it look like the gtr bonnet?
im after pictures of top of the bonnet and bottom of the bonnet.
what did you use to cut it with? angle grinder?
https://www.sau.com.au/forums/topic/304799-gtr-bonnet-lip/#findComment-5054405
thats because genuine gtr bonnet's are made of aluminium and gts-t bonnets are made of metal.
i dont really want to pay 500 for a bonnet + gtr hinges to make it fit as i only like the appearance.
maybe i should rust proof mine.. a some coats of primer should help aye?
im just waiting for my lip to come in, hope its in one piece and doesnt come snapped.
https://www.sau.com.au/forums/topic/304799-gtr-bonnet-lip/#findComment-5054419
exact same reason with me, didn't really want to spend that much for just a bonnet when its going to look exactly the same!
and the sikaflex worked really well i don't think its ever going to come off! lol
heres a pic for those thinking to do the same
needs a wash from all the finger prints on there :D
https://www.sau.com.au/forums/topic/304799-gtr-bonnet-lip/#findComment-5055126
oh and bert_ i actually bought the bonnet chopped with the lip, i just sanded it down really good making sure everything was smooth and put it together using "sikaflex" as told to by the users above (thanks!) :D
im guessing angle grinder?
heres a pic
doesnt look to appealing but looks perfect from the outside haha
Edited by wAAA`
https://www.sau.com.au/forums/topic/304799-gtr-bonnet-lip/#findComment-5055143
oh and bert_ i actually bought the bonnet chopped with the lip, i just sanded it down really good making sure everything was smooth and put it together using "sikaflex" as told to by the users above (thanks!) :)
heres a pic
thanks for the picture, haha well its the outside appearance that matters. i was just afraid of cutting it and having a massive gap that air could get in and lift my bonnet. but thats just me being paranoid.
ive got a carbon lip do you think ill be able to glue it on aswell using sikaflex?
Edited by bert_
https://www.sau.com.au/forums/topic/304799-gtr-bonnet-lip/#findComment-5055362
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
