R33 Gtst Sedan. Pearl White Paint Job. For Sale.
Hey guys, 1994 GTST sedan with 5MT for sale. Pearl White paint coat which is hard to see from photos as the colour changes from different angles. Car was purchased from Southern Special Vehicles end of NOV 2008. I am the first owner in australia. Rego has been paid till 2010 nov.
Never Been on track and car is washed regularly. Selling due to going overseas.
Car is seviced regularly and tuned at Chasers Motorworks with all mods done at chasers as well.
ATW after tuning: 180KW (Dyno Chart Attached)
100ks Servicing done about immediately when the car was purchased, all belts changed.
129 ***Kms has been done.
Details Listed Below. Most parts fitted less than half a year ago.
Exterior
1. Painted in Pearl White (View in person to see)
2. Genuine JUN rear pods and side Skirts. Replica M Sports Front Bar (Fitted and Painted at MICOLOUR)
3. Carbon Fiber Bonnet with vents.
4. Tinted Windows
5. GTR Front Grill
6. 15CM Led Strip In White on Headlight
7. Chrome Headlight
Wheels & Tyres
1. 18" Monza Japan Wheels
2. 235/40/18 Falken Ze329 Almost new.
Interior
1. Genuine MOMO Competition Steering Wheel 350MM
2. Razo 340G Gear Knob
3. Carbon Look Gear Boot and Handbrake Boot
4. Chrome Speedo Insert
5. Genuine Recaro Seat with low rails.
In Car Entertainment and Security
1. 2-Way Spy Alarm System (Fitted By Doug from Eastside Installs)
2. MB Quart Rear Speakers
3. Linear Series Front Speakers (Fitted Last week at Autobarn) with Tweeters and Titanium Dome Tweeters
4. Clarion Headunit with USB and Aux In
Suspension & Handling
1. Tien Basic coilovers
2. Front Strut Bar
Electronics
1. Greddy Pro Fec B Boost Controller (Tuned by chasers)
2. Apexi Pen Replica Turbo Timer
3. 52mm Autogauge Boost Gauge
Engine And Drivetrain
1. Exedy Heavy duty Clutch
2. N1 Water Pump (Fitted when 100ks servicing was done)
3. Blitz LM Front Mount intercooler
4. Drift Pod Filter
5. 5zigen Pro Racer Full exhaust system
Rego till: 20 Nov 2010
Price: $13600 Neg No RWC.
Car is in very good condition. Parked in secured parking.
Contact: Daniel 0422627059.
Cheers.
  • 1 month later...
 Share
    • we can only guess exactly what happened from our keyboards, but to me it looks like they were targeting 27 but the wastegate was too small or poorly controlled and the boost crept up, that is quite common
    • Good points!  Took those for granted - though I *did* actually give an example of winding boost up more than it had been before where I wasn't actually specifically looking for more peak power.  The Toyota Starlet dyno plot that I shared and mentioned showed an overlay from the previous tune it had and the one I'd redone, I left the boost targetting the same as the old tune but then after peak power I ramped boost up by a good 5psi or so over what the old tune had at the same rpm. The reason I felt comfortable with this (though the owner of the car had a "are you sure?" moment when I suggested it) is that the setup wasn't turbo limited, it was largely head sealing limited and the owner was a bit concerned as for the last few seasons he'd had issues with head lifting - sometimes not completing an event without having some headgasket issue, so he didn't want to run any more boost than it was. The reasons I was ok with raising the boost a good 5+psi MORE than that was that I left it where it was in the middle, and only increased it where VE (and therefore cylinder pressure vs psi) were dropping hard and I didn't stop the torque from dropping, just reduced the drop.  Well, there is that and the fact that the previous tuner had it overtimed by near 7degrees at peak torque - but that's another story haha.    I didn't really go into detail about that "turning it up more" thing but now you've mentioned the "not detuning", sometimes the boost *can* be turned up higher than you'd expect if the setup allows for it and you do it smartly.  I've tuned things to run 30psi on BP98 "safely" that a few years ago (or still?) people would cry that it was a stupid idea - but given they were well intercooled, low EMAP turbos and only doing that kind of boost where VE is dropping etc I was pretty confident it wasn't as cowboy as it sounded at face value and we never ended up with issues as a result of it.
    • they choose the number of psi (27) around 4200? Could it produce more at this engine speed with the same turbo?
    • one thing escapes me, if the turbo spool provides the maximum boost and we can't control anything before that, how can the boost be higher by it alone.   here around 27 psi at 4200 then up to 32 psi at 6500 rpm   how does the tuner do this
    • I'm still not sure what you are trying to acheive, but I wanted to clarify something about Lithium's response to your question...   Only within certain limits. All of the examples Lithium gave were of detuning for a particular reason. Before the engine/turbo/wastegate combination has hit full boost, you can't increase it....the wastegate is shut and the turbo is pushing as hard as it can Once the combination has hit the target (controlled) boost, you generally have full control over whether it makes more or less boost, because it is being limited/reduced from its potential. This is generally done by controlling the wastegate In the top end, with an undersized turbo, it is possible you won't get to your target boost anymore if the turbo is choking up. In this case you cannot increase boost any more without changing the setup. No change in cost compared to any decent build, other than tuning time to get the engine to make less power than it is able to at a certain point
