My shipping back would be by USPS Global Priority which would have tracking, but the cost of it would be added in the price of the repair. For the clock it would be around $25 vs the normal US price of $5. I've shipped many things back and forth all over the world. I was big into Tamiya RC cars for a long time and got great deals into and out of Japan and Australia. Very familiar with worldwide shipping none the less. I'm moving from New Mexico to Oregon on June 1st for work so I've suspended all repairs and incoming shipping until after I'm settled in up there, but I can easily take care of it once I'm all set up again. Repairs take me about 6 hours total including testing, but I can only do them on my days off. Turn around has still been fairly quick. Usually inside of a week. If you can't find a local service keep me in mind.
  • 3 years later...
On 12/1/2014 at 5:38 PM, Samuel Leonard said:
Yes, it was the resistors under the VFD. I now have a rework station and I'm happy if people want to post them to me and I'll post them back. I live in SA. Just text or call
0431 398 657
Hey mate u still doin this or??
  • 5 years later...
Sorry, I know this is an old one but just trying to get mine going and preserve all the items the car has from the factory.
It was completely dead. Have removed the display and reflowed and tested the resistors under there and that got it to power on but the buttons don't work.  So I replaced the buttons and reflowed every component on it but still no joy.
I guess the OKI chip is fried but just in case anyone came across something similar and fixed it, please let me know 👍
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
