Hello,
I have 2 Greddy gauges and some pods for sale. All gauges are electronic (memory and warning) with the control box and wires.
All sensors are included with the gauges. Basically just need to be wired up and there ready to go.
Condition: Excellent
Gauges: All 60mm
1. Water Temp (Will sell with the radiator hose sensor and Samco hose)
2. Air Fuel Ratio (Includes Sensor that needs to mounted to exhaust - Needs to be wired up - had to cut to remove from car)
Looking for $175 each FIRM.
As for the pods: (From R33 GTS-T S2)
A-Pillar twin - $40 (Pick up only)
Dash Mounted Tripple - $40 (Pick up only)
Just send me a PM if your interested.
I have pictures of the gauges with all the included gear. Will post them up tonight.
Cheers
what suburb are you in, im after the gauge pod, got any pics of how it sits on the dash?
Edited by W0rp3D
Hey mate,
Im in Ormond. (Just near Caulfield).
Ill try and dig up some pics. If you have a passenger airbag i would NOT recommend this. It sits over that side of the dash and is angled towards the driver.
Cheers
Hey mate,
Cheers
Mine is a S1, no airbags.
No worries,
Ill get some photos of it on the dash.
Are S1 and S2 different shaped dash?
Cheers
Will have a look at pics but i dont think so, just that S2 has the passenger side airbag.
Ok so fitting should be ok. Ill get some pics of what it looks like.
Cheers
Water Temp gauge is sold.
Everything else still available.
Sorry W0rp3D i haven't had a chance to get pics of the holder on the dash. Ill do it this weekend.
Cheers
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
