Hi Guys,
Just thought I would link you to my car on the dyno at Hyperdrive.
Just wanted to say thanks to Oz and Cem for all the hard work they have put into my car.
Also thanks to Andrew at Hyperdrive for doing such a great job on the tune and looking after me.
Also what oil cooler kit would you recommend me buying and from where?
I would like one before I do a track day.....! :D
Cheers,
Ken
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/
  Hanaldo said:
Well done man, that thing is beasty!
What plans have you got for it in the future?
Thanks Martin!
Not sure but I only wanted 350 out if it at the start but I got 400 so im happy (at the moment) haha....
I will take it to the drags soon and im thinking of joining SAUWA but I don't seem to find the time to even hit the drags :D
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5046961
  stormtrooper said:
Nice one mate :) Love that thing, really do, you've put so much work into it, has to be the cleanest R34 I have seen in a LONG time.
Now get your mate to buy my GTR.......... ;)
Thanks Chris :D
No your keeping the gtr, its mint!
How dare you try to sell it haha :)
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047241
Nice. Hyperdrive do great work and Andy is a champ.
Is yours external or internal and is it 0.82?
You got to love the gt3076r i couldnt be happpiers with mine. I just wish i had a 3litre
Edited by Pattygtst
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047433
  monga said:
That's a sweet achievement mate, especially on Hyperdrives roller.
Thanks Clint, yeah hyperdrives dyno is harsh...
I was thinking of going All Star for a power run on the Hubs and getting a better looking dyno graph...
But thats being a hp fan boy haha ;)
Mine is internal but im using cams with 17psi from a GT3076 so it works well.
I went for internal to keep it street friendly :)
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047461
I went for internal to keep it street friendly :rofl2:
I have same turbo but external gate for my 34 sedan, also have tomei cams , greddy plenum , 6 boost with 50mm trust gate .. Andy will tune it once i done all the fab work
  Hanaldo said:
Hey just as a matter of interest, whats this thing like on petrol?
LOL choose 1 .. power or fuel economy :domokun:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049033
Its actually not to bad.. but it really depends how you drive.
When I just had the basic bolt on mods with a tune I was pulling 400-410 on full tank (BP Ultimate 98).
Right now I average about 370-380 on a full tank but like I said really depends how you drive the car :domokun:
Nice, with the external gate you will be able to boost it much harder.. Engine Stock internals? Just the cams done?
Also I would like a greddy plenum, that is my next engine mod... Makes the engine bay look like SEX :rofl2:
Edited by KEN-R34
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049065
Lol yeh i know its not going to be efficient, i just wanted to know how much he gets to a tank driving like he usually does.
Just to be the devils advocate, i know of a certain eco car that does 0-60 in 2.5 seconds. The Shelby Ultimate Aero EV has 1000hp, 800lb-ft of torque, and gets 400-500kms out of a charge. Absolutely no petrol involved :rofl2:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049074
Also I would like a greddy plenum, that is my next engine mod... Makes the engine bay look like SEX :domokun:
Im only after 400 . Neo in my 31 has greddy plenum on it , from throttle body to cooler the pipe is 300ish long :rofl2:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049168
  SKYRYAN said:
The 'Fuel Economy & Hippies' forum is that way..
lol...
  Dsturbd said:
Im only after 400 . Neo in my 31 has greddy plenum on it , from throttle body to cooler the pipe is 300ish long :P
You will make 400 easy on your 34.
Going for 400+ RB25 with stock internals is a bit risky but then again depends how you drive it.
Your 34 is a track car right? Your going to give it a good thrash most of the time :(
How man ks has your neo done?
I would like to know how long your engine lasts with 400 usage on the track.
Don't mean that in a bad way at all.... could last a very long time who knows.
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049293
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 馃挭馃徏 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 馃ゲ But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
    • That is correct,  I have a forged RB25/30det NEO hiding away safely and I wanted to use the very rare greddy vct adj cam gear on this new setup and so I just used the whole thing on my s1 instead of pulling it appear because I'm lazy af 馃槄馃馃徏
