  • Replies 40
if you want it to be loud and look drift spec and jdm and <insert any other ricer term> then go for the cannon. if you want a muffler that gives a good note but isn't annoying as hell to drive with, then get a 2.5" oval muffler.
then would a 3" twin muffler be as bad? would it drone alot?
If you've already got a 2" exhaust, then yes, to get it to fit would be fairly straight forward for any exhaust shop.
I recommend you ask someone with a similar exhaust about noise. I reckon it would be loud though.
do canons still drone with the silencer on?
Nope not usually. It's typically the best way to have a legal car, and when you hit the track you take it out.
The other time it might be useful is if the neighbours are complete twats, and you want to stir them up a bit, you take it out. Give them a blip of RB goodness off the limiter while they are yelling saying they are going to kill each other etc. All you can hear is that beautiful music of 6 cylinders humming in progression of chaotic melody. Certainly drowns them out. I recommend it.
Iv got a 2 1/4 inch exhaust with one resonator and a 2.5" twin square tip muffler, sounds nice and is right on the legal db limit.
your intake piping also comes into play when you modify your exhaust i think, i removed all the stock piping on my car and it made it louder and gave it a nice sucking sound
Edited by R34 -_-
thanks. so you would recommend a canon with a silencer ?:kiss:
Cannon are a pain. They drone like hell on any NA skyline, you need like 2 resinators to get rid of the drone, too much pointless spending. Get somthing that works well.
Definatly worth the $2000 kakimoto R cat-back and custom cat, front pipe and HPC extractors :rofl:
you have an NA skyline. anything with a big outlet is going to make the car noisier and drone more. that one like you posted from ebay won't be that bad though as it is only the tips that are 3". where it passes through the muffler is still only 2.5" so it won't be that bad, but if the muffler has poor quality packing then it may still sound bad.
a full custom made 2.5" cat back exhaust with a good rear muffler and centre resonator should only set you back about $500 and will give a good note while not being too loud.
as for the cannon with the silencer, yes they cut down the drone, but they do also look stupid with the silencer in them. just get a good quality 2.5" oval muffler and then find a nice tip for it (and not one of those ones from supercheap, etc that are held on by a screw/clamp).
I had a long coby resonator and another shorter/fatter resonator on my car at one stage with a 4" cannon and that wasn't even close to being drony, it was rather quiet until 5k rpm and even then it still wasn't a deep drony sound
Ive got a 2.5 inch straight to a resonator then straight into a 5 inch cannon, get a loud deep roar all the way till about 7k revs then you can here the it pinging the rest of the way.
Came like this from japan, only thing ive had to change was the Resonator, the new one gave it a deeper sound, and ive also had the cannon mounted with rubber type holders to give it some free moment if it shakes or gets bumped, ive had the weld crack before and it gave an awful metal rattle on start up with a big knock.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
