Hi All
Recently purchase a set of factory reverse camera from Si long Bao. As the unit was for sedan and the wire has been heavily modified to fit the aftermarket unit. I want it restore to factory wire to fit my factory coupe. Need some one in sydney have a coupe with reverse camera show me their boot?
Thanks 100 times for any help.
Frank
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
