well got myself a 1989 r32 shell back in october 09. has basically everything minus engine and diff. in a few months i will be hopefully be getting a 1jz-gte installed by nizzpro performance.
http://www.nizzproperformance.com.au/conversions.html (top right)
after a little bit of research, i decided this was the route i wanted to take, and found a shell that had basically everything minus what is included in this package.
***pics soon***
mods that i am planning to install to get the car running:
HSD - HR Type Coilovers http://www.otomoto.com.au/HDSystems/hrseries.htm
KAAZ L.S.D - Basic - 1.5 Way http://www.slidingperformance.com/store/in...mp;productid=74
future mods that aren't so important:
- haven't decided yet, but either 17" or 18" wheels with a decent offset
- comfy bucket seats for driver and passenger
- gauges, boost controller etc.
- upgraded brakes (rotors, pads and brake lines)
https://www.sau.com.au/forums/topic/304937-soon-to-be-1jz-gte-r32/
iv been looking around at different brakes, ecu's, coilovers and gauges and decided on the following:
dba slotted rotors, hawk hps performance pads, goodridge braided brake lines, tien super street coilovers, defi gauges and a kaaz lsd (probably a 2way).
after i while of getting used to the car il be upgrading to a microtech ecu with hand controller, aluminium radiator and some 17" rims.
God damn a 1J in there will be pretty crazy to drive I reckon. They go good in a fat arse soarer imagine it with only 1250 kgs to push!
Just out of intrest sake do you know what your 1J weighs?? and is it VVTI?
Cheers.
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
skylines still in the shop. apparently they been a bit busy, dont really care so not rushing them. crossmember and custom engine mounts are done. engine will be in and mostly wired by end of week. Organised with nizzpro to get a rwc done there, so i can drive it home wootwoo!!
went down to see the progress today. just waiting on my mate to email me the pics.
during this week:
-custom crossmember and custom engine mounts were made
-engine was prepped and dropped in place
-the coilovers and slotted rotors that i supplied are installed
-put on a T70 turbo
-hicas lock bar installed
by next weekend when i go down next, most of the wiring will be done, fmic will be installed, and exhaust will probably be done.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
