Need help with boots controller!
R30_turbo
 Share
Hey guys.... I tried to install a boost controller on my HR30 and i have run into a few problems.
today i was attempting to install my Turbosmart gated boost controller with my mate, and we didnt have much success. It has a triple hybrid turbo. the compressor is standard i think and the exhaust is from some comodore. the response was very out of wack and sometimes it wouldnt come on boost at all. basically it was behaving nothing like it should, and we were 100% sure of all installation points... any ideas??
we also after having no success with the first item, tried another model that my freind had awaiting employment in his car, and had the exact same result. we had not turned up the boost at all, and it was behaving very oddly.
any help PLEASE!
Also why is there a tee coming from the compressor housing and the outlet pipe and feeding the wastegate actuator? Isn't there normally only one coming from the outlet pipe and feeding the actuator?
do they both need to be connected or can i block one?
I really need some advise on this. Any help would be much appreciated. :D
it should go from the intercooler pipe to the bootcontroller then to actuator just one hose,
the arrow on the boost controler should be on the same path towards the actuator
the hose that i am using with the boost controller conected runs between the actuator and a Y junktion with both of those tubes running into the turbo
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
