Hey guys, only just recently i have had trouble with my engine misfiring bad. Its an R33 26 with big single in an R32 GTS-T, WOLF 3d, near brand new plugs gapped to .7, stock coils. It has never happened before until it was about 30deg the other night and usually after about 15mins of normal driving it starts.
I was driving along at about 4000 rpm in second and it started sounding like your typical boxer engine, and assumed an injector plug had come off as it's done it to me before. Checked all plugs and the problem stopped . . . maybe not. Started the car up, sounded good, drove along and it came back then disappeared, came back, disappeared etc. it even happens on idle sometimes (it's an extremely rapid misfire sounding like a machine gun haha)
Doesn't matter what gear or what rpm but gets really bad when you load the engine up or stay on constant throttle, and if you hit boost it will go away sometimes. The stock oil pressure gauge in the dash will get close to zero then jump to about 4, then just fall and rise as it pleases. Engine doesn't blow smoke and no oil in turbo inlet or exhaust.
I have checked all plugs and had to change number one as it looked fried (less than 2000km old).The rest still look new
Cut out each injector while car was running to see if there was no change on one. all good though
Changed fuel filter over in case it was blocked
I'm guessing i should just seal my coils with silicone and do a comp test but while i'm there should i be looking at anything else.
Any help appreciated
Edited by AE86 Spoontah
No i havent and there is no AFM. . .
but i have a theory after drivng home today. Another hot day and after 10 mins it started happening. Checked all injector plugs again an no change to engine noise to it's got to be the coil packs. Reason i'm thinking this is that there are hairline cracks in the coils and when under bonnet temps get too hot, the cracks expand and the spark jumps out. I'm sealing them up now so i'll see if that fixes the problem.
double check that coil plugs "click" when you attach it as it's happened before where loose connection causes intermittent misfiring
They all click apart from no.1 but you can't pull no.1 plug off unless you release it how you normally would
Sealed up coils with some quick cure high temp sealant but hasn't fixed the problem. It's gotta be electrical is it "pops" alot more now and the pops are louder like there is bulk fuel being ignited.
Could there be a problem with my ignitor?
Hi there, dunno what your problem is but seems like there are two which could be related. If you have sealed up your cracked coilpacks & the sealant has had sufficient time to completely cure without fixing problem or as you say making it worse I would be borrowing some known good coilpacks to substitute & check. Also I'm told that the factory Nissan oil pressure senders/gauges on Skylines are notoriously dodgy but you could also have bad electrical earthing causing your combined problem.
My 2c
Cheers GW
My 2c
Cheers GW
I might have to borrow my mates Splitfires and see if that helps. I heard to that the factory gauges shit at the best of times
too.
Put mates Splitfire's in and worked for about 10mins and the problem came back again so it's not the coils. Put my standard coils back in, sprayed coil pack module with contact cleaner and kept the vally cover off this time and the problem didn't come back after 10 mins, so i gave it a boot and it did it abit on boost. Maybe the coil pack module is getting too hot? Any one got a CPM i can borrow in Perth to test for 5 mins? Cheers
Found that the problem was the ignitor was getting too much heat soak in the hot weather so i relocated it next to the brake booster and have no problems with misfiring even on a 40 degree day. Crisis averted haha
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
