hello all, i have a R34 GT-T 1998 model.. 2 door.
some of u probly already posted to my other noob threads but im getting better :D
It is completely stock at the moment and i have a few ideas for it and im in the middle of chasing up quotes etc
some of you may of already seen my posts but at this stage i have pretty much made up my mind i just got a few q's to ease my mind a bit before i start blowing some dosh :)
Basicly this is what i have gatherd so far... im still a bit torn between pod/fmic as the gtt already has a smic good for 200rwkw and thats all i want... i think the only reason i could justify spending the extra money is if im not going to reach my goal with my stock cooler and pod then i can go for a fmic and a performance filter in my box. Also do brands play a part in anything as i have nfi on brands or what to use... and i like the 3" exhaust but if i go 3" all the way it may be too loud but i dont want to restrict flow? im going to contact my tuner today and ring around for pricing so yeh i guess the more info i have the better... is there any advise you guys recommend before contacting shops?
Here is a list of what i have in mind so far.
Nissan R34 GT-T 1998 White
Engine/Performance: 200Rwkw Goal.
Stage 1:
Engine test before any mods. & Dyno run
Sparkplugs/Coilpacks: Replace with new Spitfires/yellow jackets? & Japanese performance spark plugs (ngk irradiums?)
Exhaust: Full exhaust, Dump pipe 3" open bell mouth, 3" high flow cat(info) 3"
Back end high flow muffler (Bigger size cat?) (twin tip) dont want it too loud but still want a nice sound no droning sound etc..
Intake: Pod style air filter, heat shield, cold air intake (use the stock one?) or new front mount cooler.
Stage 2:
Boost increase: Electronic boost controller 10psi constant, remove 2 stage controller.
Ecu/Tune : Nistune software. (dont need to spend big $ for the power i want)
Exterior/Interior - Main WHITE - with colour coded dark/black colours.
18" Shadow Chrome/Black Rims (like the 34 gtr rims too expensive.) buddy style rims?
Front Bumper/Lip: Like the black lip on the bottom of the GTR - series 2 front with lip.
Boost gauge replaced with psi reading boost gauge / replace all gauges.
Pedals: Series 2 style pedals.
New gear shift nob: (stock one is slightly loose in set position)
Suspension: 1" lower after rims are put on possible coilovers? (like how car is handling at the moment just want to lower it)
Brakes: performance brake pads/calipers - to match colour code
Rear wing: Carbon fiber tipping. "on sides of wing and where wing is mounted"
Purchased / Installed
Sound System:
Alpine SPE17CS 6.5" 210watt & Tweeter fronts $140
Pioneer TSA1673s 6.0" 220Watt Rears $100
Pioneer DEH-4150SD 4-channel high power wma/mp3/aac/cd receiver with usb direct ^ built in sd head unit. $280
https://www.sau.com.au/forums/topic/304986-r34-gt-t-about-to-drop-some-mods-in/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
